Putting together a clutch setup
Old 06-10-2009, 12:26 PM
beastls1's Avatar
Default Putting together a clutch setup
hey guys i have a 00z...my clutch is starting to slip....i went with the ram 910hd clutch and billet flywheel now i am about to order a master and a slave....my questions are do i have to stick with ram or could i go to another brand with them also do i have to get a throwout bearing also...
Old 06-10-2009, 12:33 PM
ttranssam's Avatar
any ls1 clutch will work, id recomend monster and as far as the stock slave and master, they will work fine. Just replace them with new ones. I do highly recomend a tick performance master cylinder. check ws6 stores clutches to see all your options. any other questions just pm me
Old 06-10-2009, 12:35 PM
ttranssam's Avatar
almost ant throw out bearing will work...just before the install read this...youll thank me later... https://ls1tech.com/forums/manual-tr...need-shim.html
Old 06-10-2009, 02:57 PM
Gen414's Avatar
Are you saying you ALREADY bought a clutch? Or the clutch you have is the ram 910hd and IT is starting to slip?
Old 06-11-2009, 10:20 AM
beastls1's Avatar
i already bought the ram clutch and flywheel... the stock set up is whats slipping
Old 06-11-2009, 10:34 AM
Matt@SNLPerformance's Avatar
I would suggest a stock replacement slave and a Tick master cylinder, we sell both. give me a call and I can get them on the way to you.
Matt
817-750-2000
Quick Reply: Putting together a clutch setup
