Just ordered AFR 205 Heads
Finally bit the bullet on these. Wasn't cheap thats for sure. What kind of numbers do you guys think I will get. Comments suggestions Thanks
Breakdown:
LS7 Lifters w/ LS2 Trays
SVO #30Lb injectors
Crane 1.8 Roller rockers Total valve lift is .589 intake
AFR Heads Milled to 62cc w/ 7.350 pushrods
Pacesetter LT With FM Merge collector into LM Exhaust
222/228/115 Vinci/Crane Cam
Vinci Tuner
Centerforce Dual friction clutch
170 degree thermostat
LS6 intake
ASP Pulley
SLP Lid, Screen removed MAF w/ center piece removed
Strut tower brace and UMI SFC
Breakdown:
SVO #30Lb injectors
Vinci Tuner
LS6 intake
ASP Pulley
