oil on intake valves and bolts wtf! help
Old 06-10-2009, 10:58 PM
shaun's Avatar
Unhappy oil on intake valves and bolts wtf! help
hey guys i pulled my intake and found a little bit of oil on the intake valves and when i pulled the intake bolts out there was oil on the threads.
i had a bbk intake that i dident like so i took it off and put my ls1 intake on for now and i noticed this.
when i put the bbk on i also added a catch can from the ws6 store and after a few track outings and some normal driving i pulled the bbk to return it so could i really have still been geting that much oil in the intake ports?
because there was a good amount of oil on and around the intake ports.
help me out guys
Old 06-11-2009, 12:56 AM
00SS6spd's Avatar
Pull the spark plug from that cylinder, check to see if there's oil on it. If there is you could have bent valves, bad rings, bad valve seals... A compression and leakdown test will give you the answer to that. I remember I had oil on a few of my plugs, used a spark plug adapter on an air line... All of the air was coming back out the intake runner with both valves closed, bent valves FTL
Quick Reply: oil on intake valves and bolts wtf! help
