Flex Injector help for 5.3 to ls1 intake swap
Old 06-11-2009, 09:17 AM
46Coupe's Avatar
Default Flex Injector help for 5.3 to ls1 intake swap
I am running a 2006 L59 engine in my 46 coupe. For a few reasons I am swapping over to the LS1 intake. I bought an intake and rails so I can complete the swap.
I know my truck injectors won't fit in the LS1 rail. Simple solution would be get my ls1 injectors re-manned and run them. However it is my understanding that the Flex fuel injectors are 34#. I'm not sure if there is anything else special about them to run E85.
So my question is, what car style injectors can I use on my LS1 fuel rail that will allow me to continue using the flex fuel capability?
Thanks in advance!
Mark
Old 06-11-2009, 11:10 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
You could send me your computer for a reflash and get a set of the 24508208 injectors from us. We have them right now for $25/each. They are rated at 36lb/hr. You would also need the adapter ends for the injedtors as they have the old style EV1 plugs.
Hope that helps.
Quick Reply: Flex Injector help for 5.3 to ls1 intake swap
