NGK spark plugs
sawzall wielding director
When I looked into this, it appeared that the original spec from GM was 0.060. Which was revised to 0.040. The interesting thing is that it was revised when they switched to the iridium tipped plugs, there was a discussion on a forum somewhere that the reason for the new gap spec was that it was required for the iridium tipped plugs and not for the older copper electrode plugs. I think that I ended up gapping my plugs at 0.040 and meant to keep increasing the gap to 0.060 every couple weeks to see if there was a difference.....not that I ever got around to that LOL
The smaller gap means the coils are not stressed as much as the larger gap...
and 0.040 is still sufficiently well wide enough to get a sufficiently large spark.
thanks guys, i actually gapped the tr55's at .050 and is running quite well, but now 2 weeks later its got a slight missfire when at running temp at times. I dont know what could be causing this, i only feel it at iddle and when shifting gears, its weird
