Spacers in the rear?
Old 06-12-2009, 02:27 PM
keith_AE2010's Avatar
Default Spacers in the rear?
Soon I am going to have a set of 15x8 draglites on the rear of my 98 camaro. I will have bfg street tires on them for now and they will be street driven.
My question is this: I don't really want to grind much, so how much of a spacer should I run? In other words, how much gets ground down for you guys that just grind and don't run a spacer?
I will be going to a 3.5 inch ARP wheels studs to make sure I have enough threads for the lug nuts with the spacer. This is the one.
http://www.summitracing.com/parts/ARP-100-7713/
I was thinking about a 1/2 inch spacer. I don't care if they stick out a little, just don't wanna grind...and I definitely wanna be safe about it all.
Does the new studs and spacers sound good with these or will I still have to grind some for the draglites. These are stock brakes and weld draglites.
Old 06-12-2009, 06:21 PM
Those are the right studs, correct?
I think they are. Someone has to have done this before. I searched, but maybe didn't find the right thread.
Old 06-12-2009, 10:54 PM
Any body? I figured I would get more hits. Or does everybody just grind?
Old 06-18-2009, 06:51 PM
Up again.
Old 06-18-2009, 10:13 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
yes those are the correct studs
Old 06-18-2009, 10:18 PM
Thank you very much. I had used summit and jegs combined to see which ones, just wanted to make sure.
Old 09-12-2009, 12:53 PM
kevins2000LS1's Avatar
did you use a 1/2" rear spacer?
Old 09-15-2009, 03:12 PM
No, they were 4.5 bs so they didn't really rub.
