Ratio 3.73
Old 06-12-2009, 03:23 PM
Blue Thunder LS1's Avatar
Default Ratio 3.73
hello,
I am from saudi arabia and there are no one to install camaro ratio perfectlly without noise
I have 02 a4 z28 camaro and recentlly i bought rechmond ratio and it is broke now becuse to much noise and I well buy another one so, i need instructions about how to install it
thanks
Old 06-12-2009, 03:47 PM
ROCNDAV's Avatar
If you are doing it yourself with aftermarket gears, get a Shim tool to let you know how much you have to shim the pinion. I think there are some write ups on here if you search the appropriate section.
Old 06-12-2009, 03:51 PM
BIG_MIKE2005's Avatar
Try the drivetrain section instead of engine internal section & you'll find out what you need to know a little easier. Lots of info in there on different ratios & install tips.
Old 06-12-2009, 04:02 PM
SOMbitch's Avatar
Originally Posted by Blue Thunder LS1
hello,
thanks
Search the Yukon gear website. Best write up I have ever read. http://www.corvette-restoration.com/...structions.pdf
