They should fit. They're roughly the same height as stock tires. You just may have to worry about a little inner fender rub, depending on the backspacing of your rims. You could either BFH the inner fenders, or run a small spacer.
Post a pic. You could have 16s or 17s depending on year, options, things. But, the base was a 16 X 8. In which case you can fit a big slick on, like 26x10.5 or sox16.
