Drag Racing Tech
need some help on lt1 setup
Old 06-12-2009, 11:22 PM
nofordfan's Avatar
Default need some help on lt1 setup
hello everyone i have a 1994 lt1 camaro been building for last year so i took it to track and it only runs 8.38 in 1/8 mile at 83 mph 1.8 60 foot i just think it should run beter times and need some advise but heres what it has factory heads ported double angle vavle job ported intake and throtle body has .510 INTAKE LIFT / DUR.@.050 .230 DEGREES
.520 EXHAUST LIFT / DUR. @.050 .236 DEGREES
LOBE SEPERATION IS II0 camshaft with 1.6 ratio rockers the best crane makes triple vavle springs and hardin pushrods it has been tuned also has long tube pacesetters 30# injectors airfoil k&n filter new opti ,o2sensors stock bottom end but all new has 4100 stall th 350 built 456 gears in ford 9inch with spohn tunnel arm and street ets basically cars new but with these mods shouldnt it run better # s thanks any help is apricated
