Conversions & Hybrids - 73 Nova Air ride 6.0l turbo swap thread.... Now running
73 nova guy
06-12-2009, 11:26 PM
http://img199.imageshack.us/img199/3930/p1030698i.th.jpg (http://img199.imageshack.us/i/p1030698i.jpg/)
http://img193.imageshack.us/img193/7175/p1030688z.th.jpg (http://img193.imageshack.us/i/p1030688z.jpg/)
well this is what i got. i am in the beginning stages of my 5.7/ls1 swap. the trans i will be using will be a 4l80e. the car has a built th350 in it now that was bolted to the 350 AFR heads and a b@m blower that i hurt last year at the track the car made two passes one one street tires the car went 12.80 with a 2.90 60ft spinning the tires hard in first and second on 26"/8" slicks the car 1.70 60ft and at the 1000ft the car went poof and smoke and oil every were the car went 12.40 coasting threw the traps and that was the end of the 350 blower motor... the th350 will go for the 4l80e.
i have not decided yet if i am using a single turbo or twin turbo setup. i go back and forth about what is going to happen i guess it depends what i can get my hands on first.
so lets see. the past few weeks i have been working on the motor cleaning it up and taking all the stuff to do some cleaning http://img268.imageshack.us/img268/6582/photo2xbe.th.jpg (http://img268.imageshack.us/i/photo2xbe.jpg/)
http://img142.imageshack.us/img142/2617/photo21.th.jpg (http://img142.imageshack.us/i/photo21.jpg/)
tonite i got a few hours to start to rip the car apppart the blower and the heads have been sold so its just bare motor now will make it easy to extract!
http://img198.imageshack.us/img198/6316/photo3gpf.th.jpg (http://img198.imageshack.us/i/photo3gpf.jpg/)
http://img197.imageshack.us/img197/9452/photo4w.th.jpg (http://img197.imageshack.us/i/photo4w.jpg/)
so this is now it begins i dont have alot done yet. and im on a build as i can afford budget so i may move a little slow. this is also my first ever turbo car so that will be a curve.. but i will have lots of pictures and questions for sure!
sorry i just pre viewed the tread and the pictures suck thank apple and the iphone!
jbsjunk
06-13-2009, 09:03 AM
Love it! I had a 73 for many years and went thru a few different builds. Ended up selling it to a racer. Been thinking about getting a hatchback next.
I'll be watching this.
gayslowassNALSjunk
06-13-2009, 09:14 AM
Hatchbacks are where it's at. I love mine!
73 nova guy
06-13-2009, 08:24 PM
well a little more work done today i got the sub frame removed and got the old heap off the sub frame..
http://img196.imageshack.us/img196/733/photo7t.jpg (http://img196.imageshack.us/i/photo7t.jpg/)
i guess there is metal under all that grease this is its first time out of the car in 36 years so its got lots of pain undercoat and crap rocks dirt every thing you can think of
http://img197.imageshack.us/img197/7203/photo6a.jpg (http://img197.imageshack.us/i/photo6a.jpg/)
as you can see my garage is not finished.
http://img199.imageshack.us/img199/8899/photo5a.jpg (http://img199.imageshack.us/i/photo5a.jpg/)
a little teaser
http://img199.imageshack.us/img199/1214/photo9a.jpg (http://img199.imageshack.us/i/photo9a.jpg/)
jbsjunk
06-14-2009, 08:03 AM
Noice. How much did the body bolts fight ya?
73 nova guy
06-14-2009, 09:11 AM
Well the the rear two were out once like two years ago for the supframe bars. The from ones were virgans seen wd-40 and the ingersol thunder gun and they were out! It amazing too this is a PA car land of salt! The worst part was getting the subframe to slide out of the tie bars that took me a wile since the car is ladder bared in the back the tie ins are welded in.
MeanYellowZ
06-16-2009, 05:14 PM
I wish the exhaust manifolds fit facing forward like that........
73 nova guy
06-21-2009, 02:15 PM
i hope they do? i haven't had the motor on the sub frame yet so i don't no. they look to clear the accessory i am using vette ls1 stuff.
Stu Cool
06-21-2009, 09:53 PM
What frame mounts are those?
thanks
Pat
73 nova guy
06-21-2009, 11:15 PM
thanks
Pat
oh boy good question there a few years old i need to think a sec. i believe there moroso mounts for a nova sbc. i plan to reuse them
ya check there site
#62630 Solid Motor Mount Pad Kit. Zinc and yellow chromate plating. 1974-81 Camaro/Firebird; 1973-88 Chevelle, Malibu, El Camino, Monte Carlo; 1973-79 Nova; 1976-90 Impala, Caprice; Small Block, use with Moroso Steel Motor Mounts No. 62515
Stu Cool
06-22-2009, 07:58 AM
Thanks!
jbsjunk
06-22-2009, 08:40 PM
Just FYI, those are solid mounts. 73+ Novas used rubber frame mounts and steel shells for the motor side, smiler to the newer trucks.
73 nova guy
06-22-2009, 11:15 PM
yup i had to change both sides because the shells were to big to fit the mounts. i plan to use these in my ls setup.
MeanYellowZ
06-23-2009, 10:06 AM
I tested the C6 vette, ls truck, ls car, '10 Camaro, CTS-V, C5 vette, and GTO manifolds on this Turbo 73 Nova Im doing and no luck on any of them facing down. I think only one set even came close to fitting the right direction fitting down and out the back.
hookemdevils22
06-23-2009, 12:56 PM
love it... it would have been fun to test those drums at the top end doing 11s. man, with all the turbo builds, i'm thinking i should drop the CR on my build to accomodate a couple. and to think, i can get garretts for cost...
73 nova guy
06-23-2009, 11:34 PM
well that's nice to know i didn't want to take on a set of custom headers yet but i guess it will be in order. all tho i would like to retain the a/c and putting the manifolds on the right way may be the option to look into then make a sharp turn to get the exhaust forward may be an option
73 nova guy
06-23-2009, 11:38 PM
i don't no how to do two quotes in one reply so ill do it this way.
hehe the drums don't scare me i ran close to 11.00's last year with them and it was fine i would think low 10.00's may be a little tricky. they are power drum so that helps a lot. i don't drive the car on the street like an idiot so i don't mind them. 4wheel discs are in the future
MeanYellowZ
06-27-2009, 01:03 PM
Here are a few pics of the one Im doing, using the C6 vette manifolds flipped upside down...
http://i43.tinypic.com/28v63nl.jpg
http://i39.tinypic.com/2u5x79t.jpg
olblue51
06-27-2009, 07:11 PM
I'm using the same frame mounts in my '73 Camaro. It was a former drag race car when I bought it and those were the mounts it came with. On the motor side I'm using Edelbrock adapter plates with Prothane motor mounts. I did have to trim the upper rounded part of the frame mounts off so the prothanes would sit lower and the bolt holes would line up...
http://i80.photobucket.com/albums/j179/olblue51/MotorMounts-1.jpg
04600rr
06-27-2009, 09:03 PM
meanyellowZ how does that thing get water? it looks like the hot side runs right against it....
73 nova guy
06-28-2009, 08:57 AM
i had a set of those manifolds that i sold on here.
MeanYellowZ
06-28-2009, 09:20 AM
It will have a CSR straight thermostat housing on it
73 nova guy
06-28-2009, 10:54 AM
well slow going here i was away camping last weekend so i didnt get to touch the car i have also been trying to finish my garage and make improvements to tools so its putting a damper on the budget.
well this weekend i got a few hours to work on the car. this was in between putting a new pool liner in my neighbors pool and working on my moms car.
so here we go Friday i took a trip to the local junk yard and picked up a 4l60e just to get some mock up done i dont no if i will keep the 60 or go to an 80e yet. the 80e's are hard to find here.
so this is what i got a 4l60e
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo5-1.jpg
so i bolted it up and stuck the hole thing on the sub frame. then i stopped for a :chug: cold beverage and took some measurements of the stock motor mounts and the carshop mount plates and made my own solid setup
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050051.jpg
this is my second time with a tig welder what do you think?
here is a pic of the truck manifolds and the nova cross member
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050042.jpg
not going to work with the truck manifolds lol.
i also got the firewall stripped down so that i can do some smoothing on it and
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050029.jpg
well that's what i got for the weekend. i will try to get the trans mount in today. then i need to decide what i am going to do with the headers.. don't no if i am going to go all out with a set of stainless turbo headers or cut up a set of sbc headers and make them into turbo jobs or just do a the truck manifolds the right way and do a cross over..
73 nova guy
07-02-2009, 10:21 PM
well i have been working on the oil pan for three night's now and the problem i face is that i have no ground clearance. most pans i look at have like 8 1/2 inches of drop for the pan rail. being that my car has air bags when i drop it down at the show the sub frame is about 1/2 inch of the ground witch leaves me with about 4 3/4's. so i am using a stock Vette wing pan and cutting the crapola out of it and building a new sump. i had the motor all mounted in and every thing was good till i put the power steering pump and the alt on and the hit the upper A arm so i had to move the motor forward so i had to start over... with the pan:bang:
so tomorrow i hope to finish the pan then i can start on the headers
i hope to post some new pictures tomorrow..
last night was my first time welding aluminum so i took most of the night welding up some scraps... wow is all i can say
73 nova guy
07-05-2009, 11:34 PM
well not much to report over the weekend i took the orginal frame mounts off because they were way to short and the motor was not sitting in the right spot. it was way to low. so i decided to put the sub frame back in the can and then remake the frame mounts. i also want the radiator support in so i can start building the headers. i should have the parts to start that this week some time if the big brown truck shows. here are a few..
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050063-1-1.jpg
the more i put stuff back together the less header room i have hehe. i keep saying oh boy :chug:
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050064.jpg
73 nova guy
07-06-2009, 04:24 PM
well the big brown truck came today! the header parts and the some of the cross over parts! http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo6-1.jpg
73 nova guy
07-08-2009, 11:04 PM
well about 5 or 6 hours and this is the drivers side so far.. i didn't think it looked to bad for the first time i ever tried something of this complexity
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo10.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo7-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo9-1.jpg:chug:
eviltwin_1987
07-08-2009, 11:08 PM
header looks great. speedway motors kit?
73 nova guy
07-08-2009, 11:15 PM
yes sir! speedy shipping. i was going to use stainless but. spoke with a friend that owns a fab shop and he gave me some first timer advice and do it this way much cheaper for make mistakes
mac_z_28
07-10-2009, 10:35 PM
do you mind me asking what the price range was for the headers? jw
73 nova guy
07-10-2009, 10:37 PM
185$ not bad for a first timer
eviltwin_1987
07-10-2009, 11:58 PM
i used one of those kits when building the headers for my brothers 5.3 nova. its a great deal for what you get. i didnt like the flange thickness though.
73 nova guy
07-11-2009, 12:22 AM
its not a bad kit but... the flanges are not the best and there is no collector stars that would be nice. one other thing the one collector was the wrong size one is right for 1 3/4 pipe the other i got is for 1 5/8 pipe and i got the 1 3/4 pipe so the first one i did the collector fits like poopie.
73 nova guy
07-11-2009, 12:33 AM
well i with a ton of welding i got the drivers side done what a job to tig all those tubes up! i give new respect to those that build headers wow and now understand the price behind them! i am proud never tried any thing of this complexity i hope the work ok!!!!!
now i hope to have the other done this weekend if i dont drink to much tomorrow i may get it mocked up! ha :chug:
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo12.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo11.jpg
73 nova guy
07-16-2009, 11:35 PM
well finally i finished up the headers! here is some pics of the passenger side. i don't think it turned out as well as the drivers but it will do.
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo10-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo11-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo.jpg
now i can start the cross over and then i am on hold till i get a turbo :(
hookemdevils22
07-17-2009, 08:48 AM
lookin' nasty (in a good way)! you said those are 304ss? they look like stainless.
73 nova guy
07-17-2009, 08:57 AM
No I wish they were ss there just mild steel. I hope they hold up for a wile. U spoke with a friend that's a very good fabricator and he said for my first time to go mild for my first time. I plan to coat and wrap them. Thanks tho!
73 nova guy
07-19-2009, 08:55 PM
well i am on hold with the turbo setup. i am still waiting to get a turbo i hope this week! but so i have been working on the oil pan
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo14.jpg
chevellepowered
07-20-2009, 09:49 AM
awsome headers.. i was thinking about doing a log set up on my chevelle..good work and hurry up and buy the turbo already,,haha..
V8 FC
07-20-2009, 10:11 AM
man i use to love your car now i hate it! (because you got your ls1 in before i did)..lol let me know if you need help man i can swing down some time!
73 nova guy
07-30-2009, 11:37 PM
well a little bit of an update..
i got a turbo here its a mp70/.96ar
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo23.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo5-2.jpg
So i got it mocked in place as you can see i kinda screwed my self with the passenger header but that's what i get for not starting with the turbo in place then building the headers... i don't want to redo the passenger header so ill build around it. i plan to modify the inner fender well to fit around the turbo.
the first thing i did today was mount the intercooler were i wanted it. i had to notch the rad support and the hood pop to get the intercooler to fit. then i built some brackets to hold it in there.
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo4-1.jpg
one other problem i see i am going to have is that the intake to the turbo is pretty close to the rad support. it will be tricky to get the filter to fit. i will have to come up with some custom setup there of course.
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo-1.jpg
73 nova guy
08-02-2009, 07:03 PM
well this is what i got for the cross over. i am not all that happy with it... the passenger header is to close and didn't leave me with much room to build the y for the turbo. i may cut it all apart and start over.. i am going to sleep on it and well see.
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo22.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo4-2.jpg
73 nova guy
08-05-2009, 12:22 AM
little update today got toying with some ic piping
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo8.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo9-2.jpg
MeanYellowZ
08-05-2009, 03:09 PM
lookin neat....Im pretty much done with the pipe fab on the 73 Im doing.
73 nova guy
08-08-2009, 06:30 PM
a little up date got most of the cold tubing done. still waiting on WG and BV
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050335.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050336.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050337.jpg
73 nova guy
08-16-2009, 06:55 PM
today's playin around in the hot garage.. i got this done besides getting a little swamp ass....
i moved both inlet and outlet to the same side and converted the rad to dual pass.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050349.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050351.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050352.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050354.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050355.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050356.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050357.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050359.jpg
i also got some work done on the down pipe..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050360.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050363.jpg
chevellepowered
08-16-2009, 08:15 PM
bad ass man,, can wait to see some vids... of it running.. we have a 71 nova im trying to get my brother to do a lsx turbo swap.. good luck man. you'll love the insane power!!
frojoe
08-16-2009, 09:30 PM
So I guess you're not planning on running inner fenders? I know there isn't a lot of room in these Nova's, but that's one of a couple things I want to make work.
71 chevy
08-16-2009, 11:10 PM
looks great.
how come you are taking the downpipe on the outside of the frame rail? is it gonna dump right where it is , or are the muffler plans?
I plan to route my dp on the inside of the the frame rails
73 nova guy
08-17-2009, 11:14 AM
i do plan to run fender wells. but they may be custom or heavenly modified like everything else...
the down pipe is not finished yet there will be oval that tucks up to the rocker.. also a cut out by the fender for track days!
mac_z_28
08-17-2009, 12:06 PM
are you just going to dump the exhaust or throw a muffler on it or????
73 nova guy
08-17-2009, 12:45 PM
it will have like a 3.5 race race bullet on it..
hookemdevils22
08-18-2009, 09:38 PM
you could run sheet metal inner fenders. i think they look pretty sweet, a buddy of mine ran them in his '67 II. just cut them around the exhaust tubing - i'm sure it would turn out great.
73 nova guy
08-18-2009, 10:51 PM
i had planed to just mod the stock inner fender. that will prob be what i end up doing.
71 chevy
08-18-2009, 11:11 PM
hey, how much was the pipe kit for the headers and where can I find it?
73 nova guy
08-19-2009, 08:58 AM
http://www.speedwaymotors.com/Chevy-LS1-Header-Kits,6600.html
mac_z_28
08-21-2009, 10:34 PM
Are you rollin on Torque Thrust II's? if you are im going to shoot myself... were doing the exact same build and were going to be on the exact same wheels....wtf
73 nova guy
08-22-2009, 04:50 PM
yes sir that would be the ones! its ok you can copy my rid i don't mind!
well kinda tinkering around here till i get some more parts.. so i got the muffler cute little thing it is!
http://i65.photobucket.com/albums/h232/rackerman62583/photo12.jpg
and made a bracket to support the turbo
http://i65.photobucket.com/albums/h232/rackerman62583/P1050375.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050373.jpg
mac_z_28
08-22-2009, 11:44 PM
woah woah lol i cant copy if were farther along than you lol ...just weird... but hey we got different tranys!
73 nova guy
08-25-2009, 08:29 PM
well some more tinkering the fuel tank is 65% done still need to sand it down and give it a little paint job. looks damn good for 36 years old!
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050376.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050377.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050378.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050379.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050383.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/P1050384.jpg
i just ordered a hydro boost setup of a truck that will be the next project. then i think i am going to pull the drive train out and start prepping everything for paint and powder coat.
mac_z_28
09-05-2009, 02:06 AM
any new updates?!
73 nova guy
09-05-2009, 10:14 AM
not a hole lot i got the heater box patched. today i am going to switch out the ls1 for a lq4. waiting on my hydro boost to get here and then ill build some brackets for that. also waiting for parts to finish the oil pan.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050397.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050400.jpg
i also hung the front suspension on the car and got it off the jack stands!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050390.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050389.jpg
mac_z_28
09-05-2009, 10:09 PM
is the lq4 the 5.3 or 6.0? did u just want to be safer with the iron block instead of aluminum? im chancin it on the ls1 with a low amount of boost im sure. im guessing 9 pounds.
73 nova guy
09-05-2009, 11:28 PM
lq4 is a 6.0l with lower compression witch is better for more boost and from what i read it looks like the lq4 is stronger then the ls1.
71 chevy
09-06-2009, 11:59 PM
hows the build coming.
73 nova guy
09-07-2009, 02:01 AM
slow.. cash shortage have been working on some odds and ends cleaning up some stuff and finishing some welding.
mac_z_28
09-07-2009, 03:10 AM
what tunning software u going to use? and how many pounds of boost do you think you'll get up to?
73 nova guy
09-07-2009, 10:21 AM
i have efi live for tuning. i would like to see 15 at some point once the car has the bugs worked out of it and water meth. the 15 may only be on race fuel. once i get it tog and get the bugs worked out ill prob start 8.. if i could find e85 around here i would definitely go that way!
71 chevy
09-07-2009, 11:21 AM
I would think with an intercooler and meth injection that 15psi would not be out of reach at all.
Im hoping that I can ultimately get mine to 22psi with intercooler and meth
Jimbo1367
09-07-2009, 11:54 AM
Novaguy,
What is the safe boost you can run through a GM composite intake ?
thanks,
---Jim---
73 nova guy
09-07-2009, 01:22 PM
well this is a stock lq4 right now so i would like to prolong the life as much as possible. till i tare it down and do a good rotating assembly. then twin 70's will be in order!
Novaguy,
thanks,
---Jim---
Jim i don't really no the limit of the composite intake. i have seen a few up in the 20psi range. i would ask that question in the forced induction thread
73 nova guy
09-07-2009, 03:05 PM
well this is a little new crap.
oil pump pickup done. its kinda nice to leave the side of the pan open to see were the pickup is to the bottom of the pan. made the whole thing really easy. i also modified the second windage tray on in the pan so that it will keep all the oil in the bottom of the pan.. this week i should have the rest of the parts for the pan so i can finish it and call one thing done!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050403.jpgthis pick is were it was originally.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050405.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050404.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050409.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050406.jpg
i also got board and decided to hang some parts on the motor!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050415.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050417.jpg
Fbodyjunkie06
09-07-2009, 03:31 PM
Looks really good! Keep it coming!
MeanYellowZ
09-07-2009, 03:43 PM
hey I got a pic like that for a 73 Nova turbo setup.... :)
http://i25.tinypic.com/2nutz7q.jpg
73 nova guy
09-07-2009, 03:49 PM
prettty!
71 chevy
09-07-2009, 04:55 PM
73 nova, thats a fine looking engine. love the headers. I'll be mad at you if you then dont put the coils in the stock location JK. :) look at all the clearance you have. Im using the c6 exhaust manifolds and I really wish I didnt have to relocate the coils.
meanyellowz. where is a good place to relocate the coils to on a nova with no inner fenders. Im using the msd 6010 and I really would like to not have to modify the harness.
btw, where is your waste gate gonna go?
73 nova guy
09-07-2009, 10:43 PM
yes the coils will be in stock location.
i don't no were i will place the waste gate yet. i wont decide till i get it in hand and see were i have room.
frojoe
09-09-2009, 09:49 PM
That is one gangster lean you've got going on! Progress is looking great!!!
Is the notch for the downpipe so that the DP will clear stock inner fenders?
73 nova guy
09-09-2009, 10:08 PM
three boards holding the right side up and 2 for the left!
i have not tested the inner fender yet but i am 110% sure the inner fender will not fit on the passenger side! so i will have to take the cut off wheel and the welder to that to!!
73 nova guy
09-13-2009, 07:11 PM
well after about 15 times of leak testing the oil pan is leak free. so i mounted it up. i need to put the motor back in to do the hydro boost brake setup in. but decided to make the engine lift plate first.. engine will go back in this week one night..
enjoy!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050418.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050419.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050421.jpg
73 nova guy
09-19-2009, 11:02 AM
hydro booost!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050423.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050424.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050425.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050426.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050427.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050428.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050429.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050430.jpg
At6texan
09-21-2009, 12:11 PM
good build
hookemdevils22
09-21-2009, 12:35 PM
dang, your lift plate looks much nicer than mine. continue the good work bro.
67Firebird455
09-23-2009, 12:52 PM
That's an awesome setup. Where are you actually moving the coils to? I have a 67 bird, the truck manifolds don't work on it either without hitting the upper control arms. I was hoping they'd fit... =\
73 nova guy
09-23-2009, 02:37 PM
the coils will be in the factory location. yes i was hoping that the truck manifolds would work to but no luck :(
mac_z_28
09-25-2009, 09:57 PM
soooooo are you going to finish your build or sell the build?
we just fired ours up for the first time today! :o)
73 nova guy
10-04-2009, 08:49 PM
little weekend work.. took every thing apart to place the 4l80 in and finalize motor placement. the trans mount need to go back a a lot being that the 80e has a trans mount at the far end of the trans... having the sub frame out makes this task much easier, i didn't want to cut the original trans mount up so i decided to mod the sub frame so that i can put any GM trans in the car. i also not happy with the hot side cross over so i will be cutting that all apart and doing it all over..
enjoy!
also some new parts!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050450.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050451.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050452.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050453.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050454.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050455.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050456.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050457.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050458.jpg
73 nova guy
10-08-2009, 10:24 PM
well cross over 2.0 is about done.. i am pretty happy with the way it turned out. the only thing is that the tube had to go under the rad support and will be in view under the car, but it was the only way i could go about it. i also got on with mounting the gate, it will exit under the car.
i am sure i will get questions about the radiator hoses i am going to have to angle the lower rad outlet to make it clear but that is not a problem!
enjoy !
http://i65.photobucket.com/albums/h232/rackerman62583/P1050462.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050464.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050465.jpg
oh and yes it hits the balancer. it is just slid on the crank i needs to be pressed back one about a half and inch it should clear.. if you look at were the power steering pump is that is how far back the balancer goes
http://i65.photobucket.com/albums/h232/rackerman62583/P1050466.jpg
73 nova guy
11-24-2009, 05:39 PM
the new intake and elbow.. http://i65.photobucket.com/albums/h232/rackerman62583/P1050661.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050662.jpg
73 nova guy
12-02-2009, 10:58 PM
http://i65.photobucket.com/albums/h232/rackerman62583/P1050674.jpg
well i got even more parts in i got most to finish the car now just need to finish building every thing...
http://i65.photobucket.com/albums/h232/rackerman62583/P1050669.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050682.jpg
i also got the exhaust in
http://i65.photobucket.com/albums/h232/rackerman62583/P1050679.jpg
this is what it looks like done
http://i65.photobucket.com/albums/h232/rackerman62583/P1050685.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050686.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050687.jpg
06colorado
12-02-2009, 11:56 PM
nice build. Were are you going to mount your BOV?
73 nova guy
12-03-2009, 12:36 AM
its in this picture buy the rad on the driver side. it is black
73 nova guy
12-03-2009, 10:04 PM
last but not least the steel 4" hood
http://i65.photobucket.com/albums/h232/rackerman62583/P1050693.jpg
JoeNathan78
12-04-2009, 01:21 AM
:hail: man thats going to be one bad ass ride...
frojoe
12-04-2009, 01:50 PM
Is the large cowl for intake elbow clearance or just for baby-eating aggressive looks?
73 nova guy
12-04-2009, 04:00 PM
the second!!
73 nova guy
12-07-2009, 08:33 AM
i am pretty much done with all the major stuff now i am on to the little things. got the filter mounted on the frame rail. its nice when you have a turbo car and the headers face forward leaves room for all the other shit ya need!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050697.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050696.jpg
i also got the rear done c clip eliminators installed and got the new cover installed!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050698.jpg
73 nova guy
12-09-2009, 10:04 PM
well that's all i am going to fab the car is coming apart for paint!
the fuel pump bracket nice rubber isolators to stop the noisy A1000 mill.
threaded and taped a plate then welded the plate to the frame rail bolts on all fancy.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050701.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050699.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050702.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050705.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050706.jpg
crosstraining
12-09-2009, 10:13 PM
Man, that is 1 sweet ride.
You got me thinkin I need a turbo, but I have an LQ9. I heard they are not ideal because of the flat top pistons and compression. Oh well, next project maybe.
I can't wait to see/hear yours!
73 nova guy
12-17-2009, 11:37 PM
got the hood fitted ton. i had to cut some of the structure out of the hood to make it fit.. i did some measuring first then got the cutoff wheel out and went to town!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050707.jpg
finished product.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050712.jpg
closes on the first try! i was amazed i measured something right and it fit the first time.. its a milestone in my life lol...
http://i65.photobucket.com/albums/h232/rackerman62583/P1050714.jpg
this is a cheap ebay hood. but it is the best fitting cowl hood i have ever seen the lines are nice and there is no waves! im very pleased with it..
the oven produce a few nice powder coated parts ton to!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050711.jpg
chevellepowered
12-27-2009, 10:02 PM
hell yea.. cant wait to see the finished product..
73 nova guy
01-01-2010, 05:07 PM
well you ask whats is going with that turbo nova!? well i sounds quite on the forum but my garage has been busy sanding my brains out!
so for i got the fire wall cleaned up and got a bunch of holes filled and primed i will paint them tom as well as for the sub frame that is ready to be painted too..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050723-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050724.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050725.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050726.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050727.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050728.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050729.jpg
that's if for today once this is done i can start on the suspension and the rad support..
cgslow77
01-01-2010, 05:44 PM
good work.. thats goin to be a nasty street car when its finished
73 nova guy
01-03-2010, 12:13 AM
well its painted now its time to put shit back tog!!!!!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050733.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050734.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050735.jpg
Jimbo1367
01-03-2010, 11:43 AM
get working and take pics!!!
73 nova guy
01-09-2010, 01:06 AM
well update time i got a few more things done.. i got most of the suspension done and reinstalled.. thanks to Matt W for the bolt fishing in the subframe..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050741.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050742.jpg
Note: the air lines are just setup for the time being so i can put air in the front bags to move the car.
Umi tire rod end sleeves just because..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050743.jpg
another thing i did is install some arp 2000 rod bolts.. now i am sure ill get some flack about this.. i know you are should re size the rods when you change the bolts... there are many guys that do this and dont have a problem.. but you have to remember that this is a 900 dollar long block so i figure i rather have it spin a rod bearing and destroy the crank then brake a stock rod bolt and chuck a rod a ruin the block.. oh well time will tell...
http://i65.photobucket.com/albums/h232/rackerman62583/P1050740.jpg
i also got the block sanded and primed ill shoot the block tomorrow..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050744.jpg
71 chevy
01-09-2010, 01:12 AM
I was just looking at your welds. pretty good. what brand and model welder do you use if you dont mind me asking.
Great work on this project by the way.
73 nova guy
01-09-2010, 02:14 AM
i use a miller tig.. the model is a miller diversion 165
are you from the Steve's nova site?
71 chevy
01-09-2010, 02:32 AM
thanks for the info.
yep, same guy from SNS :thumbsup:
frojoe
01-09-2010, 01:16 PM
Oh man I want a Diversion 165 so badly!! Ufortunately right now I can't quite justify it just to do aluminum... yet... but in time! And yes, real nice beads you lay there!
73 nova guy
01-09-2010, 01:37 PM
oh man its an awesome entry level welder! you cant do much more then 1/4 aluminum with it.. and i likes argon because it cools with it so it cooks threw it.
73 nova guy
01-09-2010, 05:51 PM
today the motor got color! and i got the hydro boost painted and installed!
there is no reason for putting the motor in i just wanted to see it! lol
http://i65.photobucket.com/albums/h232/rackerman62583/P1050746.jpg
i had forgotten how low the car got wow!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050763.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050747.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050751.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050758.jpg
crosstraining
01-09-2010, 09:28 PM
Lookin' good. I like the wheels. It looks like you still have the drums on the front. Are you going to disc? Sorry if you talked about this earlier I'm too lazy to back and read:angel:
frojoe
01-09-2010, 11:48 PM
Holy shit... this is TOO COOL. How so low? Just from having no (deflated) suspension? Mine needs to be somewhat close to this height.
73 nova guy
01-10-2010, 12:05 PM
thats it no suspension lol
73 nova guy
01-12-2010, 12:00 AM
Tonie i decided to stab my self with some fuel line tonight... so i put the fuel system together.....
I phone photo's My form of SLR! haha
http://i65.photobucket.com/albums/h232/rackerman62583/1263273609.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/1263273611.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/1263273613.jpg
i also decided to start build a rig to test this oil pan.. i found this piece of 1/8 Plexiglas and it is just barley the right size! luck be with me.. so i drilled it up bolted it on.. i need to get a bolt on valve stem so i can put air in it.. first ill fill it up with water and put some air in it possibly 10psi and see were the water shoots out!! i have one problem i dont have a legit plug for the -12 oil return line so i may have to come up with some thing for that..
http://i65.photobucket.com/albums/h232/rackerman62583/1263273612.jpg
blazin
01-13-2010, 10:09 PM
Few quick questions for ya.
Engine mounts? Moroso lowers with car shop plates with tabs?
4l80e clear the stock trans tunnel with out cutting?
frojoe
01-13-2010, 10:43 PM
That intake/elbow combo with the faced Edelbrock logo look tight... Digging the silver/black fittings too!
BLULS1Z28
01-13-2010, 11:02 PM
i just did a 8.1 with a f1 and air ride for a guy in a 71 so i feel your pain ihad that motor in and out probally 10 times checking things and making this and that. car flew and the guy totaled 3 days after we finished painting it wish i got pics but time wasnt on my side
73 nova guy
01-17-2010, 10:16 AM
the motor mounts are all custom built both the engine plates and the frame plates..
the 4l80e does fit the trans tunnel without mod but the sub frame had to me moddified to use a stock trans mount. but you can build a different trans mount that would work with out modifying the sub frame
that sucks!
Bowtie_Aaron
01-17-2010, 11:45 AM
MITB does not approve of this tread.
aaron
73 nova guy
01-17-2010, 03:17 PM
aaron
you lost boy? looking for the lt1 section??? :lol:
BLULS1Z28
01-17-2010, 05:50 PM
it would suck worse if it was my car but things happen thats what insurance is for. i just had to send all the invoices for the car to the insurance company. have to go friday to pick up customers new project 69 camaro and all the parts he ordered for it
BLULS1Z28
01-17-2010, 05:51 PM
its another extreme deadline feb 15 9 am running driving on to hauler to florida
73 nova guy
01-19-2010, 07:31 PM
UPDATE on parts got the headers back tonight! should have the rest of the turbo system back my the weekend!!!
the rest is of the turbo system will be black..
these are ceramic coated..
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050774.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050776.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050777.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050778.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050779.jpg
that should be enough to make your mouth water i no mine is!
themachasy
01-20-2010, 01:56 PM
beautiful headers! I'm hoping mine turn out that nice!
73 nova guy
01-20-2010, 08:33 PM
the turbo!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050785.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050786.jpg
frojoe
01-20-2010, 08:58 PM
WOW those parts are pretty... I'm so jealous of your progress!!!!
How come the the 2 O2 bungs on driver side primaries but seemingly none anywhere else? Just put them there for simplicity-sake? I would've thought maybe 1 in each collector or worst-case both in the DP.
73 nova guy
01-20-2010, 09:06 PM
those just some bolts for a heat shield for the brake booster
73 nova guy
01-22-2010, 11:13 PM
What can i say i like stainless!! just about every bolt is now stainless Allen except for the few i specialty ones and the graded stuff.. :)
http://i65.photobucket.com/albums/h232/rackerman62583/P1050799.jpg
all the coil pack stuff too! god this thing is sexy
http://i65.photobucket.com/albums/h232/rackerman62583/P1050800.jpg
jbsjunk
01-23-2010, 12:09 AM
Wish I had my 73 again......... Might be in it's 14th incarnation by now.
Remember the old saying "If it don't go, chrome it"? I don't see any chrome.:D
73 nova guy
01-24-2010, 06:09 PM
well thats it i got the rest of the turbo stuff back! i just need to pull the motor back out and put the pan and the trans one it. then its time for the massive wiring project..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050802.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050811.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050812.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050813.jpg
a couple guys asked why there was bungs on the header on the drivers side. if you look under the master there is a fancy heat shield there!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050817.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050821.jpg
frojoe
01-24-2010, 11:46 PM
Damn.... that's all I got to say. I want to see how the radiator will fit (and intercooler?)... Looks fantastic man!!
SIC LSX
01-24-2010, 11:58 PM
Its a sweet ass ride, but one year from being perfect :)
frojoe
01-25-2010, 12:26 AM
Also, what size wastgate & bov are you running?
73 nova guy
01-25-2010, 08:29 AM
gate is 44mm and the bov is 50mm
73 nova guy
01-30-2010, 12:31 AM
this is what i got so far.. i took all the pins out of the pcm plugs and labeled all the pins. i now plugged all the plugs into there sensors and started zip tying all the clumps together so that i can group all the wires the way i want..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050851.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050852.jpg
the welding table has turned into the wiring station!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050847.jpg
carnage!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050849.jpg
73 nova guy
02-01-2010, 12:25 AM
well i got these plugs from harry's scrap yard a few weeks ago.. i payed so much for them i have too use them!!!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050865.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050866.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050864.jpg
i originally wanted to put the pcm in the car under the drivers seat... but the dang thing doesn't fit under there plus if i ever change the seats it could pose a problem.. so i thought well ill put it in the glove box like everyone else does.. then after some thought and a bunch of wasted time i decided in the cowl would work nicely.. so i wracked a hole in it made this fancy bracket to mount the pcm to and made a bolt in filler piece..
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050853.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050854.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050855.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050856.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/CopyofP1050858.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050862.jpg
its not my best work but it will do..
73 nova guy
02-04-2010, 11:06 AM
some new...
I got most of the engine harness done. it looks like a mess but it has came out really nice.. there is two main plugs for the engine so that it can be removed with the harness still attached to the engine. when you look at the motor you dont see many wires even with them not loomed. with the throttle body sideways it hides a lot of the plugs.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050869.jpg
also i tore the dash out and took the main harness out and removed the factory fuse box out, i should have the new harness in the next day or two then i can start on that.. what a friggen job this is...
http://i65.photobucket.com/albums/h232/rackerman62583/P1050868.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050870.jpg
ill tell you what they use some thick wires in 1973 most are 10 gauge at least. the main starter wire on this ls motor is only like 8 gauge..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050871.jpg
SIC LSX
02-04-2010, 11:30 AM
man your going to fry alternators, you have somewhere else to put it? Will it work down by the stock f-body location?
73 nova guy
02-04-2010, 12:34 PM
yeah its a problem i need to address i just haven't came up with a simple fix yet.. i want to move the alternator north some and build a heat shield for it but my tig weld broke and is out getting repaired.. once i get it back well see what i can do.. s
i would like to try fbody stuff but i dont want to change all the drive setup.. plus i thing if i do fbody then it will just fry the power steering pump..
SIC LSX
02-04-2010, 01:29 PM
Put and manual steering box in it! I traded my power steering setup for a manual box and with 15x8 front wheels it steered really easy and i liked it way better then old power steering on my 72 nova. When i put the 15x3.5s on it felt like power steering again. Just a thought! I never had to strain to steer it! hell i was 16 driving it with no problems. LOL im 29 now lol
SIC LSX
02-04-2010, 01:34 PM
dont no if these will work for you?
http://www.exoticperformanceplus.com/performance_parts/index.html?item=944
or maybe this
http://www.clubcobra.com/photopost/data/500/11409alternator_mount1.jpg
or
http://img168.imageshack.us/img168/1571/altmountpx7.jpg
just some ideas
SIC LSX
02-04-2010, 01:36 PM
I say take all that PS, alternator crap off and sell it and make ya own mount! It will look so much better and be less weight! It looks like even the low mounts may not work for you! So i would build your own mount on front of the driver side head. It easy to do and you will be happy with it and not fry alternators!
73 nova guy
02-04-2010, 04:35 PM
the car has hydro boost brakes.. i need to retain the power steering.. im going to try a different alternator or make a new bracket..
lavoy
02-04-2010, 04:49 PM
what tracks do you race at in PA? I run at beaver mostly and numidia now and then, Ill be at beaver on friday nights with my turbo LS1 this season.
73 nova guy
02-04-2010, 04:54 PM
we run at island. but my car will prob only see the track once or twice a year...
SIC LSX
02-04-2010, 04:58 PM
My nova Didnt have power brakes and my manual steering box was great. It felt a lot more under control going down the road. The manual brakes have a stiffer pedal but when ya put you foot down, its locked down! With as fast as your going to go i would loose those drum brakes! at least the front swapped :) take some more weight off and stop safer!
73 nova guy
02-04-2010, 04:59 PM
My nova Didnt have power brakes and my manual steering box was great. It felt a lot more under control going down the road. The manual brakes have a stiffer pedal but when ya put you for down its locked down!
i am to far along to do away with the hydro boost just because of an alternator location.. ill make some thing work!
73 nova guy
02-04-2010, 08:51 PM
well i am working on many things at once so i jump around.. i have this problem with the alternator being to close to the header.. so a buddy of mine brought me over a s10 alternator to try and it has a little different bolt offset that i can make work and it is also a bit smaller in diameter and now i have much more room.. i think this will work if i wrap the header with wrap and build a nice heat shield around the alternator
http://i65.photobucket.com/albums/h232/rackerman62583/P1050872.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050873.jpg
before with the vette alternator
slonoma
02-05-2010, 07:41 AM
All I can say is Wow. That is going to be one awsome car. Keep up the good work.
73 nova guy
02-13-2010, 02:38 AM
i took the night off from the wiring i have been working on for like two weeks!! what a job that is an understatement!
The hydro boost and power steering lines are done!! i know the fittings are not black.. but with the high pressure line they dont make the fittings in black.. so ill have to live with it.
and let me tell ya these fittings do not swivel what a pain in the ass trying to line them up!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050895.jpg
also i got into the shift kit for the trans... i have done one or two of these in th350's before so i have a little bit of experience with them.. the 4l80e's are known for high line pressure so you have to drill a hole in the valve body and install this spring thing. and drill another hole in the side witch was fun to drill at an angle!!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050887.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050888.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050889.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050890.jpg
one of the hole's i had to drill..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050891.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050892.jpg
now i am waiting on the converter then i can pull the motor back out and put this shit back in for the last time!!
73 nova guy
02-21-2010, 05:25 PM
well i was hoping the converter would show up Friday so i could put the motor and trans in for the last time.. but no luck.. it was kinda good tho i had a bunch of lines and things that i need to install and titty up.
yesterday i went to my buddy's garage with the diesel truck and used his lathe to build a brass bushing for the master cylinder and a rod for the shut off switch for the trunk.
here is the bushing.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050898.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050899.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050901.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050900.jpg
the stainless rod that i turned down and threaded for the on/off switch for the trunk
http://i65.photobucket.com/albums/h232/rackerman62583/P1050902.jpg
this also showed up :)
http://i65.photobucket.com/albums/h232/rackerman62583/P1050897.jpg
73 nova guy
02-25-2010, 11:16 PM
the converter.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050903.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050904.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050905.jpg
i got a bunch of shit done today since the motor is home i can put alot of shit together for the last time. i love new parts they go together so nicely..
the intake is on the valley is on injectors are in. the oil feed for the turbo worked out nicely. i few wires some spark plugs and oil this bitch will run!!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050929.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050932.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050934.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050935.jpg
i have a bunch of stuff t weld yet but haven't got my welder back yet :(
SIC LSX
02-26-2010, 12:21 AM
Just a heads up. i would get a good aeromotive fuel filter! We were told the earls were junk and hold fuel back and that was from a few big names so my friend put the aeromotive on and it picked up 1 psi so it helped
http://speed-eng.com/store/images/Aeromotive%20Fuel%20Filter%20Micron.jpg
73 nova guy
02-26-2010, 12:36 AM
that is a filter for the turbo supply line.. my fuel system has two Aeromotive filters in it a 100 micron before the pump and a 10 micron after the pump!
Jimbo1367
02-26-2010, 09:05 AM
73 Nova Guy,
Did you weld up your valve covers with a Miller Diversion 165 ? Did it feel like you wish you had a little more heat? I am looking forward to seeing the completed product. Great job.
---Jim---
73 nova guy
02-26-2010, 01:15 PM
73 Nova Guy,
---Jim---
yes i did every thing with the 165 it was ok with the valve covers, but it had a hard time with the 1/4 oil pan.. the welder is back at miller right now getting repaired there was some thing wrong with it :(
73 nova guy
03-02-2010, 07:47 PM
a few shots of the back together progress..
a drink trying to decide whats next...
http://i65.photobucket.com/albums/h232/rackerman62583/P1050939.jpg
rad support painted an back on..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050940.jpg
wires finding there homes!!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050942.jpg
here is my home made on of switch setup.. i was going to buy a flaming river setup from summit but it was like 125$ so i bough a 20$ on of switch from summit and made my own.. a piece of stainless rod a friend of mine had at his shop. i put the rod in the lathe and turned both ends down to 1/4 20, i then threaded them. i then ordered a 1 inch aluminum ball from MC Master drilled and tapped it then threaded it on the rod and put the hole setup in the lathe and fined the ball to make it look a little better.. a simple heim joint thing on the other side a grommet that's what ya got..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050944.jpg
i wiped up a quick bracket to hold the switch.. and a new lever to flip the switch since the one that came with it was pot metal and there was nothing to attach the heim too..
http://i65.photobucket.com/albums/h232/rackerman62583/P1050945.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050946.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050947.jpg
hookemdevils22
03-03-2010, 09:07 PM
ah man, the days of putting a shift kit in an '80e... it seems like so long ago. you're doing well w/ the build - that thing's going to scream. i'm in my 500 mile break-in period, still haven't gotten the thing tuned correctly - tuner had a family member die, so it got put on the back burner. but i drove her home w/ no issues, now just tying up some loose ends.
ps - do away with those drums. seriously. you don't need ssbs's or anything, just at least get stock discs.
73 nova guy
03-03-2010, 10:41 PM
in time the brakes will be changed! need to stop spending money and start putting miles on this car!
V8 FC
03-05-2010, 10:18 AM
whats the updates man :)
73 nova guy
03-13-2010, 09:51 PM
well i have been working on any thing i can until i get some cash for more parts. i have most of the wiring done just need to put the dash back together.
i built these two things today..
power steering reservoir. i still need to do the fill and return bungs.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050960.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050961.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050962.jpg
Also i finished the breather tank.. this setup i way over kill but it looks cool!
http://i65.photobucket.com/albums/h232/rackerman62583/P1050948.jpg
nice little oil drain on the bottom.
http://i65.photobucket.com/albums/h232/rackerman62583/P1050951.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050952.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1050956.jpg
V8 FC
03-13-2010, 10:00 PM
looks good man! i love the tanks
73 nova guy
03-22-2010, 08:00 AM
today! it started!
http://img.photobucket.com/albums/v479/denmah/cars/ryanova/startup1.jpg
http://img.photobucket.com/albums/v479/denmah/cars/ryanova/startup2.jpg
http://img.photobucket.com/albums/v479/denmah/cars/ryanova/startup3.jpg
http://img.photobucket.com/albums/v479/denmah/cars/ryanova/startup4.jpg
http://img.photobucket.com/albums/v479/denmah/cars/ryanova/startup5.jpg
http://www.youtube.com/watch?v=b06rRLRHU40
we fixed the vacuum leak and had the car running for a few minutes. no belt it broke the idler off so we didn't let it run long.
slownova73
03-22-2010, 03:26 PM
its perfect man!! :hump::hail:
frojoe
03-22-2010, 08:01 PM
Yeah I'm pretty jealous too......
crosstraining
03-27-2010, 09:23 PM
Dang, that really sounds sweeeettt. Even just hearing that little bit. I am seriously considering a turbo or 2 now......
jasonsnova
03-27-2010, 09:48 PM
Looks awesome!
tirefryin_s10
03-27-2010, 11:27 PM
Looks like you did your turbo the same as mine.... Looks good, The car looks great overall! Good work.
blazin
03-28-2010, 02:58 AM
Glad to hear its alive! I had a question what went wrong with your welder? Im pretty sure the high freq went outta mine I have to scratch start it,pain in the ass lol.
Mustang605
03-28-2010, 03:01 PM
I freakin love it
73 nova guy
04-10-2010, 07:56 PM
just an info update with the car. i have been working a little slow the car runs and i am trying to finalize the wiring and figuring out a few odds and ends.. i should have the drive shaft in a week or so then it an move on its own power!
the goal is still to take it to the ocean city Maryland cruise in may..
AmericanMuscle313
04-14-2010, 02:16 AM
Keep up the good work! Great build and lots of good info.
73 nova guy
04-21-2010, 09:51 PM
well i drove the car around the block yesterday for the first time. had a few leaks i have to figure out. the trans pan was leaking i just needed to snug the bolts up a bit. the power steering/hydro boost is a piece of shit it pisses fluid and does not work. be sides that i need to adjust the body panels get the hood painted and it looks like its good to go.
i did load the car up for a little compressor surge and it was good!
ModularTurbo
05-04-2010, 12:17 AM
I'm really impressed great work dude.
73 nova guy
05-04-2010, 09:41 AM
thanks rob! thanks for lookin..
i put about 70 or 80 miles on the car now its running good but i have not hammered on it yet!
novadk13
05-14-2010, 12:08 AM
Looks great! Now I need to get going on my 74 project, damn you inspiration!
89LS1RS
05-19-2010, 10:52 AM
what did you use for that steam line setup? what type of fitting is the 90 thats on the steam line, some sort of compression fitting?
73 nova guy
07-12-2010, 09:13 PM
im sorry i never responded. i just cut the end of the line off and drilled and taped for a 1/8npt fitting.
73 nova guy
07-12-2010, 09:15 PM
and update on the car..
I broke a piston in the 6.0l about two months ago. so i picked up a 5.3 and put a cam and springs into it and 317 heads and im in the process of putting it back together.
71 chevy
07-12-2010, 09:18 PM
thats the spirit
frojoe
07-12-2010, 11:32 PM
How much boost were you running? Was it from launching hard or how did it break/what from?
73 nova guy
07-12-2010, 11:43 PM
it was on 12 psi 13 degrees of timing. were were making a street pass on the car crack the limiter multiple times because of tire spin and it developed a miss due to a broken plug. we drove it home on 7 cylinders and pulled it apart to discover a broke piston in number 1cyl. the piston was broke in the ring land and down the skirt. i believe it was a fuel cut limiter problem and just beating the snot out of it..
73 nova guy
07-15-2010, 09:06 PM
http://i65.photobucket.com/albums/h232/rackerman62583/d6aa56ef.jpg ding ding round two
SIC LSX
07-15-2010, 10:06 PM
u must like the chevy orange or red hard to tell lol i think it would be pimp black but everyones different
73 nova guy
07-16-2010, 07:30 AM
Everyone uses black and the motors are black from the factory. Just trying to change It up.
jbsjunk
07-16-2010, 04:26 PM
There is always Ford blue...............:pimp:
73 nova guy
07-16-2010, 10:15 PM
yup and there is always salvage yards for fords!
73 nova guy
02-24-2011, 09:54 AM
the car all done put lots of miles on a few kinks to work out yet but i am very satisfied with the ls motor.
http://i65.photobucket.com/albums/h232/rackerman62583/P1060284-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/P1060222.jpg
SIC LSX
02-24-2011, 10:58 AM
man only if it were 72 or older it would be my fav car on this site!
73 nova guy
02-24-2011, 12:05 PM
Yeah I had first wanted a 68-72 but I found this cheap and the car has grown on my I don't mind the big bumpers. I do have a fiberglass 70 front bumper here I have had thoughts of doing a conversion but my stuff is in good condition so I can't see changing it.
SIC LSX
02-24-2011, 12:29 PM
yeah a lot of people convert the bumper and grill and it dose help! Still a nice car!
jbsjunk
02-24-2011, 03:52 PM
I want my 73 back now.
I has a sad..........
blkjck
02-24-2011, 07:24 PM
very nice car!. i want a nova and put a ls1/t56 in it.. gotta get this current project done first lol
Irish350
03-01-2011, 08:55 PM
dude such awesome attention to detail. sorry to hear about the 6.0. hows the 5.3/317s feel in comparison??
also, is there a reason the wastegate is sourced off the passenger header instead of off the post-merged charge pipe?
any more info on the bag setup? separate thread maybe?
01cherryreds10
03-02-2011, 12:13 AM
Awesome thread the Nova looks flawless. My dad had a 73' and sold it for another basket case, a 69' Camaro. Hope to get another 73' soon love the front end on them it's just different from every other Nova you see at shows.
73 nova guy
03-04-2011, 10:01 AM
i really like the 5.3 setup the car has not been back on the dyno yet but i bet it makes more power!
it looks like the gate is sourced off the one header but it is acculy sourced off both sides in the merge pipe.
here is a good pic of the setup: http://i65.photobucket.com/albums/h232/rackerman62583/P1050811.jpg
the bag setup is total custom. i do not have a thread up for that. the car was air bagged about 6 years ago it basically is a simple setup with two compressors 6 valves and 1/2 line
73 nova guy
05-05-2011, 07:28 AM
Finally dyno'd the new setup. Made 510whp/470tq
http://www.youtube.com/watch?v=qLyYmXp_C68&feature=youtube_gdata_player
eviltwin_1987
05-05-2011, 02:12 PM
Nice work. What was the boost on that run?
73 nova guy
05-05-2011, 09:57 PM
14lbs
Chicago TDP
05-06-2011, 08:37 AM
That power seems a little low for that much boost...
73 nova guy
05-06-2011, 10:53 AM
Based off of what?
73 nova guy
05-06-2011, 10:59 AM
The biggest killer is the 4l80e and not locking the converter on the dyno. Plus the tthe tune is very safe. About 11.00 afr plus we have a problem with not being able to lean the car out top end it goes way rich after 5600 and we take fuel out and it seems not to respond to the change. 5600-6300 is like 9.00afr
Chicago TDP
05-06-2011, 01:47 PM
Based off of what?
I'm not knocking it, don't think I am a hatter.
I am just reviewing some other builds where the cars are 600+ with the same boost.
But, with a safe tune and an un-locked converter, I can see the loss.
Need to make a HOT dyno run....:D
73 nova guy
05-06-2011, 09:55 PM
i would like to make a max power tune but. its more a driver then a racer so well stick the the street tune for now.
bonecrrusher
05-09-2011, 07:35 PM
Damn that car sounds awesome!
camaroboricua
05-09-2011, 08:54 PM
thats one of the sweetest rides ive seen! good job man!!!
boostedrides
05-09-2011, 09:23 PM
Cool car bro. How much do you have in the turbo kit and motor?
BanditDave
05-24-2011, 10:40 PM
Have you had any issues with the mild steel headers yet? I keep hearing it is the wrong way to go because they will crack. It make sense why they would crack but my guess is that yours are still going strong.
Reason I ask is because I just got the same header kit you did from speedway for my turbo build.
Thanks and awesome build man!
Dave
73 nova guy
08-17-2011, 09:54 PM
Dave
knock on wood i have had no problems so far and i do have a support on the turbo system to take the weight off the headers i believe that helps a lot.
73 nova guy
08-17-2011, 09:56 PM
out for lunch today!
http://youtu.be/3aYKbgyh6FE
denmah
08-24-2011, 10:48 PM
Lunch RUN!
frojoe
08-24-2011, 11:41 PM
I can't wait to have fun boosted lunch runs...
