"Need help" what turbo is this, have many pics..
Old 06-13-2009, 03:35 PM
chevellepowered's Avatar
Default "Need help" what turbo is this, have many pics..
ok i got this turbo off a city bus that gives transportation,, suntran.. came off a older model,, year?,, bus had a roots blower with this turbo going to it.. think it was 700 ci diesel.. was wondering if this turbo would work for my 5.3 turbo project.. i dont kno what this is,, think its a t4 i may be wrong t6.. please help/it also said airresearch on the turbo,,.[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 06-13-2009, 04:20 PM
BlwnLs1GTO's Avatar
Old 06-13-2009, 04:27 PM
thanks that helps alot..
could this be rebuilt better?.. or not even woth my time.. please only answer if u have knowledge about turbo's.. thanks..
Old 06-13-2009, 04:42 PM
SETc6's Avatar
its one i would not ever use. thats a big paper weight
Old 06-13-2009, 05:49 PM
theblur98ss's Avatar
I don't think I'd waste my time with that thing. How old is it and how many miles? Even if it would work I think it's seen better days.
Old 06-13-2009, 05:55 PM
Elcaballoloco's Avatar
I think I need to see pics of the measuring tape holder to give a better evaluation of this item.
Old 06-13-2009, 09:57 PM
elias_799's Avatar
looks like a t6
Old 06-13-2009, 10:01 PM
elias_799's Avatar
i love twin charged diesels. to bad they are all pretty much gone now.
i also think you will have a hard time spooling that thing with a 5.3.
keep in mind that this turbo was on massive motor that needed a blower to make up for the lag of the turbo.
Old 06-13-2009, 11:32 PM
WS6HUMMER's Avatar
Looks like it was in a fire or around salt water.
Old 06-13-2009, 11:39 PM
Gingervitis Addict
slow67's Avatar
Actually 2 stroke diesels will NOT run without the blower. They can't pull in a fresh intake charge. It is not because of the size of the turbo.
Old 06-14-2009, 12:45 AM
elias_799's Avatar
i thought that turbo was of a 4 stroke motor ? how do you know it came off a 2 stroke ?
Old 06-14-2009, 01:05 AM
Gingervitis Addict
slow67's Avatar
I don't for the OPs turbo, but I was referring to the twincharged (roots blower + turbo). No point on putting a roots blower on a standard diesel.
Old 06-14-2009, 04:13 AM
NKAWTG...N
StoleIt's Avatar
With all that rust...I would say it needs a rebuild. No way is that thing still balanced with rust on the impellers.
Old 06-14-2009, 08:58 AM
thanks.. for he replies.. yea i think the 5.3 will mot spool it up fast enough., i got this turbo for free,, this is why im asking these questions,, and i love cheap diy turbo builds.. junkyard builds.. . the intake is bout 3inchs which comes out to be 76 mm.. isnt that enough to support over 750 hp.. i kno i have to look at the exhaust housing stuff too. would it work on a big block. i cleaned it up quit a bit.. thanks for ur help...
Old 06-15-2009, 01:15 PM
LS1TECH Sponsor
DrTurbo's Avatar
TV series based unit off a DDC. Probably not worth messing with on a build unless your running a pretty big motor and not looking for alot of power.
Old 06-15-2009, 01:19 PM
Gingervitis Addict
slow67's Avatar
X2. Would probably work well for a budget BBC build.
Quick Reply: "Need help" what turbo is this, have many pics..
