New LS1 Owners - Newbie Tech - help could it be the fuel pump
View Full Version : help could it be the fuel pump
RobLS1
06-13-2009, 07:37 PM
I drive a 2000 Pontiac trans am and here one day i got on it a little getting on the highway and the car backfired a few times and cut off. Here recently i will be driving down the road and the car will just turn off for no reason. It will start right back up but just randomly it just cuts off and i can give it a little more gas then normal driving it will cut off. I think the fuel pump is going out but not sure has anybody else had this problem?
brianfromhawaii
06-14-2009, 01:31 AM
could be a ground issue, could be a few things, how about you get a fuel pressure gauge on that bitch before you blow your engine from running too lean if it is indeed a fuel issue :)
could also be your tune getting screwy due to a failing o2
SOMbitch
06-15-2009, 09:39 AM
Very easy to check. The schrader valve is on the DS fuel rail. Can't miss it. If it is below 58 psi you have found the problem.
WS6Power
06-18-2009, 10:49 PM
My car did the same thing. Turned out to be the crank position sensor.
