Rule 3700 IC pump flow test.
Coal Mining Director
Proof for me will be if it can keep the IC cool enough to start a run around 45F and end around 75-80F.
"IF" I can get all this junk hidden in the car.....
7 Second Club
Was that pump mounted inline or intank? If inline, move it intank and test and get back to me. You'll be very surprised. That pump will not work inline. Mine will shoot a 1.5" Jet blast of water 7'. It will drain a 30 gallon chest of water in 30 seconds mounted in the tank while outside takes considerably longer.
It's mounted at the bottom of a 6 gallon tank. It's the "bilge" model 3700 with the bottom basket inlet. It will also shoot a 1.5 inch stream 7-8ft out of the tank without a hose connected to it. I was going to measure open flow...but it's just too much flow to measure it accuately with what I'm using. When you add hose, IC core, etc....it still does a good job....but it flows what it flows...I did each test 5 times for accuracy.
Keep in mind...big difference between 13v and 16v. These pumps are very voltage and psi sensitive.
I could send my pump for testing if interested, I still have a little down time right now. Meziere WP 136S. It has worked great for me so far, being mounted all the way in the hatch, and the IC is in the nose, and goes through a large heat exchanger too.
I would be curious to see the results of this little 136, I know the 336 would be better.
