Generation IV Internal Engine - LS2 Rebuild: Crankshaft Question
Petraszewsky
06-14-2009, 12:01 PM
How concerned should I be about this mark on the crankshaft journal? If you enlarge the pic then you can see the small spot where it is barely pitted...From what I understand the mark was probably made by oil stravation...Would I be correct or would a small metal shaving caused this? Oh yeah and this is the only journal that has a mark like this...Thanks for any input or advice...
Petro....
Jeff Smith
06-15-2009, 09:35 PM
Replace new crankshaft or go see your local machine shop. They might tell you how it bad or good. Good Luck
Petraszewsky
06-15-2009, 09:45 PM
How much do you think it would be for a shop to polish that journal up? It's seems to me like it's right inbetween where the rod bearings set.
JFM-jr
06-15-2009, 09:59 PM
About the only good thing is it runs around the journal and not across it. I'd definatley have it looked at it may need to be ground/polished.
Petraszewsky
06-15-2009, 10:16 PM
I'll get it checked out...I'm thinking a quick polish will set it right..but then again nothing is ever that simple...haha..thanks for the input guys..
Petraszewsky
06-28-2009, 02:16 PM
I got a mirco polishing cloth out and kinda wiped around it....The black line cleaned up and the small pits were left...The rod bearings don't even touch it....I don't think it should be a problem....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
