How much of a pain?
Old 06-14-2009, 12:25 PM
Boo"SS"t's Avatar
Default How much of a pain?
Well, I'm wondering how much of a pain would it be to change the head gaskets (motor in car) with head studs on them??? I'm basically asking for some tips/advices from anyone that has done this personally. Thanks!
Old 06-14-2009, 12:34 PM
LS1CMR's Avatar
i dont think it can be done with studs, only bolts, you will have to drop the motor
Old 06-14-2009, 12:36 PM
theblur98ss's Avatar
No need to pull the motor. It's actually easier with studs since you don't have to clean out all the holes.
Old 06-14-2009, 12:45 PM
LS1CMR's Avatar
i thought it had to be dropped a few inches to clear the cowl, or was i misinformed
Old 06-14-2009, 01:01 PM
98Camarod's Avatar
I would think you would be able to loosen the k member bolts and drop it down to get enough clearance. I've never done the head studs, but I did drop the k member, there was quite a bit of room.
Old 06-14-2009, 01:09 PM
Boo"SS"t's Avatar
I was told it can be done, but it's obviously a real pain especially in the passenger's side due to the heater box. I'm hoping to get some tips/tricks from guys who actually done this and maybe ease the pain even just a bit for me...if there is such thing.
Old 06-14-2009, 02:10 PM
veee8's Avatar
Yeah its pretty easy, but you have to remove the studs. Then the heads will slide right out.
Old 06-14-2009, 02:37 PM
Restricted User
98Z28CobraKiller's Avatar
+1. Studs should come out with allen key. The worst is if you have a long tube header in the way.
Old 06-14-2009, 03:04 PM
SilverSS's Avatar
I've done it plenty of times. You may have to remove the studs before lifting the head but that's easy. The exhaust headers are what get in the way for me.
Old 06-14-2009, 03:10 PM
kenp's Avatar
That's correct. My problem was the exhaust headers too. I did not have to drop the k-member or remove any of the studs to get the heads off.
Old 06-14-2009, 03:32 PM
Boo"SS"t's Avatar
Ok. I guess removing the studs first make sense. Thanks, guys!
Old 06-14-2009, 03:35 PM
I've never had to remove the studs but I don't have the heater box to deal with either.
Old 06-15-2009, 08:53 AM
Schantin's Avatar
You DO NOT have to remove the studs, drop the engine, etc, etc. Unbolt those puppies and they come right out. I had room to spare when I removed my heads last summer.
Quick Reply: How much of a pain?
