P2V Clearance Calculation
Old 11-10-2003, 01:47 PM
Moderator
xp3nd4bl3's Avatar
Default P2V Clearance Calculation
Is there a way to calculate whether or not there should be piston to valve clearance problems with any given setup?
I have a stock bottom end 346 with milled 6.0L heads (milled .035" I believe, 63cc CC) .045" gasket, cam specs are 230/236 .598/.598 111. This same setup with a stock head gasket had no problems, I'm trying to figure out if the shorter gasket the probelm or if the cam was installed wrong.
Old 11-10-2003, 08:02 PM
strokedls1's Avatar
Doesn't sound like it would clear with that lift on milled heads. Probably need to switch to a felpro gasket and or flycut for the intake valve. Did you install it straight up dot to dot?
Quick Reply: P2V Clearance Calculation
