oil pressure issue/ hoping its the sender
ok just got my new 402 in the car and got it fired up and at a cold idle is is at 40 psi which is a little low and then when it warms up at idle is is at 20psi and while driving it goes up to 30/40 depending on RPM. i grabbed the oil sending unit and i can move the plastic part, it will turn back and forth a little..you guys think the sendning unit is the problem..i sure in the hell hope so..im going to buy one tomorrow and swop them out..let me know what you think
well i changed the sending unit in the parking lot at work last night..took about 20min and i have a nice burn mark on my wrist..motor was hot..lol..didnt really help might be 2 to 3 psi higher..guess im going to pull the front of the motor back down and change oil pump and pickup tube packing
hell no dude..reach behind the intake. go around on the drivers side and stick your right hand back around the back of the intake..arms get a little scaped up, but you can do it..i have a typhoone intake that stays hot and i did it..have a nice burn on my forearm to prove it..lol..iv changed 2 of them now that way..i dont kow if the typhoon makes a difference or not..
