SS bogs down and dies when trying to do burnout?
Old 06-16-2009, 12:41 PM
tonys02slpss's Avatar
Exclamation SS bogs down and dies when trying to do burnout?
I am having some trouble with my 2002 Camaro SS M6.I been practicing on my burnout for the track but I noticed every time I'm about to do it my car just bogs down and dies?I tried both ways dumping the clutch and hitting the break and the heel and toe method but its the same,but as soon as I let the brake go it will burn them down?I know my car has the power to do burn out but I just dont know why it's doing that?I give it enough gas too I put the gas pedal to the floor and it just dies?Need help.Thanks
Old 06-16-2009, 12:49 PM
USArmyZ28's Avatar
Did you turn off traction control? Not to insult your intelligence but it has happened.
Old 06-16-2009, 01:28 PM
99monguse's Avatar
This happened to me in the burnout box in my SS I wasn't thinking baout it when I shut the car off in the staging lanes and then started it back up for my run and backed into the water, pulled up a bit, shifted into 2nd (since I have 4.10s, to get the RPMS), revved, dumped the clutch, floored it and ppplpht...stall! I did it twice before I realized what was happening; god did I feel like a damn idiot!
Old 06-16-2009, 01:51 PM
WSsick's Avatar
i just tried my first few burnouts the other night (M6 Z28). i didnt wanna burn TOO much tire, so i pulled into some water, revved it up, pdealled the gas as not to ping the limiter a bunch, and hit the brake real quick. worked fine for me.
Old 06-16-2009, 02:58 PM
bigti99a's Avatar
sounds like traction control on to me. hit the asr switch and light um up!
Old 06-16-2009, 05:04 PM
Thats the problem I dont have traction control on my car at all.This is how it is out of 6 burnout attempts only 2 been successful?I have another question do you think my brakes are grabbing to much I put the ebc drilled and slotted rotors with hawks pads about 4 months ago maybe to much grip?I really dont think it's that I know the car has the power to do it, but also like I said if its bogging down and I let go of the brake quick it will jump right up and light them up.My tires are not even that good I have street tires which have about 30% left.
I dont have traction control on my car.I dont know why.
Old 06-16-2009, 05:17 PM
I also tried it in the rain and it still does it.But when ever I did do those two burnouts I could give it more gas and the rpm would go higher and if I let some off and got on it again it will accelerate more like a normal burnout.
Old 06-16-2009, 05:18 PM
proporio's Avatar
2002 came with traction control, do you mean that your traction control has been removed or disabled?
your problem definately sounds like the traction control kicking in.
Old 06-16-2009, 05:30 PM
tripblackls1's Avatar
ummm not all 02 came with asr
it was an option not standard
are you sure your not pressing to brake too much???
you should only apply enough pressure to the brakes as needed to hold you in one place
Old 06-16-2009, 05:31 PM
I bought the car like that it dont have traction control switch on it. They have a switch right?My just has the 35th Anniv. plaque and then a empty button and then fog lights
Old 06-16-2009, 05:39 PM
I tried that too I thought maybe I was pressing to much on the brake so I tried again and barely was holding it down and it still boged down
Old 06-16-2009, 06:23 PM
how well does your car stop?? maybe a problem with the proportionating within your brake system
just buy a line lock
Old 06-16-2009, 06:29 PM
00SS6spd's Avatar
Line lock is a good suggestion. Here's another one... Find someone you know who knows how to do a burnout. Tell them to do one in your car to see if it's your car that's the problem, or if it's just you doing it wrong.
Old 06-16-2009, 06:40 PM
Mart00SS's Avatar
Old 06-16-2009, 06:44 PM
JTSLP559's Avatar
yea man sounds like a traction control issue.. but i also like 00ss6spds idea! you never know.. again we are not trying to insult you, i have a 01 z28 and i have asr.. but it doesnt work at all i dont get a light when i click it on or anything so somehow its permanitly disable.. what a shame..
Old 06-16-2009, 06:46 PM
Alright everyone I think I found out the problem.I think my ebc rotors drilled and slotted with hawks pads are just grabbing to much and I wasn't giving it as much gas know with this brake setup so it just bogged.I reved it up to 3500rpm and dumped it and hit the brake and was able to pedal it.See before with my stock brakes and rotors I could do burnouts at 3000 rpm but know I cant.
Old 06-16-2009, 07:02 PM
I dont have traction control look.
[IMG]www.ls1tech.com/forums/picture.php?albumid=615&pictureid=26168[/IMG]
Old 06-16-2009, 07:04 PM
I dont know why I dont have traction control.
Old 06-16-2009, 07:05 PM
hahaha
i never even thought that you did not rev high enough lol
every burnout i have ever done was dropping it at 4500 +
but i also work the brake and gas with one foot
Quick Reply: SS bogs down and dies when trying to do burnout?
