Stock LS1-75 Shot- Will I regret it?
Thinking about installing a 75 dry shot on my Stock LS1 w/ 68000 miles. i am somewhat worried. How many of you have done this and regretted it?
Not me. I have 120000 miles on stock short block with 100 dry and 200 wet on 28 deg of timing. No problem so far i know thats a lot but i love gas! lol put you a 50 dry and 100 wet and youll be wayyyy happy and safe! the dry will pull enough timing and the wet will take you for a riddddeeee!!!
Guest
Posts: n/a
If the car is completely stock then you could hit the 75hp shot without a problem. I would though make sure you at least check the AFR of the car via a dyno or some sort of monitoring application so that away you knwo how the car is recacting to the nitrous.
-Chris
-Chris
