Do LS7 lifters have to be pre soaked before install?
Old 06-17-2009, 09:22 AM
corvet786c's Avatar
Default Do LS7 lifters have to be pre soaked before install?
Just as title says. Do I have to soak lifters day before install in oil. or what Plse explain??
Old 06-17-2009, 09:35 AM
BIG_MIKE2005's Avatar
I soaked mine overnight. Just toss them in a small container with enough oil to fully cover them the day before you plan to install them & they will be ready to go when you are ready to install.
Old 06-17-2009, 10:22 AM
corvet786c's Avatar
Thanks, Also I am gettin heads installed in a couple of weeks am I missing anything, heres a list of what I have:
AFR 205 milled to 62cc
2 GM MLS Gaskets
2 GM Exhaust Gaskets
16 LS7 Lifters
4 LS2 Trays
8 Ford #30 Injectors
2 Valve cover GM Gaskets
16 Crane 7.350 Pushrods
New Spark Plugs
Crank Pully Bolt
Installing 2 Polyurethane Motor Mounts
I think that is it. Can anyone think of anything else???
Old 06-17-2009, 10:36 AM
PREDATOR-Z's Avatar
Intake gaskets 8
push rod checker (if you allready do not have one)
Old 06-17-2009, 02:34 PM
Titanws6's Avatar
Are you going to go with an LS2 timing chain and LS6 ported oil pump?
Seems to be the norm when doing a H/C swap, I have them for my install.
Don't forget the gaskets for these too. What about some ARP head bolts?
And what about the TB? Have you P&P'd your stocker yet?
Old 06-17-2009, 02:43 PM
corvet786c's Avatar
Ok forgot to mention yea I put on the LS2 chain when I did my cam swap about a year ago along with new intake gaskets for LS6 and I have a new regular not ported LS6 oil pump. Yes I did get arp head bolts too. I am running stock tb with LS6 intake. I sanded it down some to make it smooth though (tb).
Old 06-17-2009, 11:47 PM
Notmyvette's Avatar
Not to steal the thread but whats the big deal with using a LS2 timing chain and LS6 oil pumps/intakes?? Considered an upgrade from the LS1 parts? What's the difference?
Old 06-18-2009, 06:07 AM
The LS2 chain is a little stronger & the LS6 intake outflows the the stock LS1. Same thing with the oil pump, it's just a upgrade.
Old 06-18-2009, 08:06 AM
Notmyvette's Avatar
So when you get LS6 or LS2 parts I assume you just say you got a car with a LS2 or 6 in it when you want a LS2 oil pump or chain etc right?
Old 06-18-2009, 08:13 AM
dmiz0420's Avatar
or order it by the part number
Old 06-18-2009, 08:16 AM
bigboykilroy's Avatar
IMO, forget a Ported Pump or SLP, Just get a Melling 10296 Oil Pump.....much beter...cast with larger ports no porting is required.
Old 06-18-2009, 08:21 AM
No, you dont tell them anything. You just order the LS6 pump & LS2 chain. It's really not very involved at all. There are only 2 LS6 pumps, one ported & one stock. And there is only 1 LS2 chain so it's hard to mess up your order.
Old 06-18-2009, 10:11 AM
Notmyvette's Avatar
I was talking about like a parts store...cant just say I want a LS6 oil pump ya know...so then where does everyone order their stuff from?
Old 06-18-2009, 10:13 AM
From the sponsors listed on the side of the page. Very few people buy parts from the local idiot parts houses unless it's just minor basic stuff like sensors, belts, fluids, hoses, ect.
Old 06-18-2009, 10:16 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
From me
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
The following users liked this post:
GregM784 (06-08-2021)
Old 06-18-2009, 10:27 AM
LS-1Z28's Avatar
no need to soak valve lifters
i just put some assembly lube on the contact points (cam/push-rod) and they will lube themselves within the first 5 minutes of starting the engine. Since the lifters won't be filled with lube they will tick until they fill with lube but it won't hurt anything unless something is different about the ls7 that I'm unaware.
Old 06-18-2009, 11:00 AM
corvet786c's Avatar
Man I cant wait until I get my AFR 205 heads should be here next week.But as soon as I get them I am supposed to go on vacation with the wife. So when I get back I already will set it up to get installed. Anybody have any Idea what kind of power I will be puttin down with mods above. (SAE only)
Old 06-18-2009, 11:32 AM
I would not do this personally. Why put the lifters thru a dry running condition when it's completely avoidable? Not smart or suggested.
If your too cheap/lazy to soak the new lifters in a little oil then put the wrenches down & step away.
Old 06-18-2009, 11:35 AM
Personally I'd ditch the 1.8 rockers & go back to 1.7, but thats just my opinion. With your cam size you might get close to your numbers you want. I'd say you'd get closer with a tad bit larger cam & Fast 90 though.
Either way it should be a solid 400hp set-up. Just remember dyno numbers aren't important, it's a tuning aid. If you think the numbers aren't impressive take it to the track before you let yourself get disappointed.
Old 06-18-2009, 12:02 PM
cals400ex's Avatar
i don't remember if i was on the comp or crane site but they recommended not soaking the lifters in oil. this was a couple years ago so their site may have changed. they did recommend cleaning them well.
Quick Reply: Do LS7 lifters have to be pre soaked before install?
