New stall, my old oil cooler good enough?
Old 06-17-2009, 10:33 AM
StealthFormula's Avatar
Default New stall, my old oil cooler good enough?
Recently I installed my rebuilt trans and Yank PT4000 Stall. My cooler is the B&M #70264 mounted on the radiator. It's rated at 24,000 GVW/14,400 BTU. I don't have a trans temp guage so I am unaware of what temp. the trans is currently running at but is that particular cooler typically good enough for a stall that loose? Just trying to get some opinions before I go ahead and either get a trans temp. guage or run a larger cooler. I did some searching and tons of people seem to be running the same cooler but haven't seen anybody with 4000ish stalls.
Old 06-17-2009, 10:40 AM
Internet Mechanic
BlackScreaminMachine's Avatar
24,000 GVW should be plenty, make sure you clean out the lines and the cooler. Also I would consider running just on that cooler and take out the cooler in the radiator. That may help as well.
You should at least have a guage for temps just incase but I have run w/o and have been fine. its a judgement call and the proper way is to have a guage.
Old 06-19-2009, 08:41 AM
Ok cool. Yup I cleaned all the lines and everything out with this spray cleaner stuff. I will definetly soon grab a gauge just to be safe.
Old 06-19-2009, 12:39 PM
cals400ex's Avatar
i am only running an 18,000 with my pt3800. i don't have a trans temp guage either but i would assume you and i would both be fine as long as the cooler is mounted in a well ventilated area.
Old 06-19-2009, 01:52 PM
allthrotle's Avatar
I think I went overkill with my cooler since its a 19row earl's temp-a-cure, part # 41906ERL but, I wanted to make sure the tranny stayed cool. my stall is only a 3600 but, with the d1 I think it stalls a little higher. I think that b&m cooler is fine for your setup.
Old 06-20-2009, 12:02 AM
dnkynrbk's Avatar
BYPASS THE RADATOR COOLER it probally has junk caught on in it I had problems with running both coolers just went to the bm one and had not a problem since so just run the lines straight to your BM cooler also flush it out and the tranny lines.
