best valvetrain / head choice for this single turbo set-up........
Old 06-17-2009, 11:00 PM
LS6427's Avatar
Default best valvetrain / head choice for this single turbo set-up........
I'm about to make a decision on whether to go FI or a big cube + spray engine.
I have an LSX iron block.
I know you don't need the best flowing heads possible for FI, so the All-Pro heads with crazy expensive parts I was going to use for the N/A + spray set-up would not be needed.
Whats a sufficient 6 bolt head for reliability for this:
422ci LSX iron block
Hogan sheet metal intake
98mm single turbo
25-28 psi
Old 06-18-2009, 08:25 AM
TurboAv's Avatar
I think the Trick Flow 6 bolt 235cc heads are reasonably priced at $2550 assembled.
http://www.summitracing.com/parts/TFS-3060T003-C03/
Old 06-18-2009, 10:12 AM
7 Second Club
BlwnTA's Avatar
Talk with Brian Tooley at TEA, I'm using the TEA/TFS 245's for a simliar set-up-see signature. Then you need to decide if your going Solid Roller or Hydraulic. I'm Hydraulic still-kinda of a unique challenge for the power level I'm at but it looks good so far.
Mark
Old 06-18-2009, 09:57 PM
LS6427's Avatar
Mark
Whats the difference in price for those 245's your using....between hyd set-up and solid set-up.
I have no problem going solid.
Old 06-19-2009, 04:28 PM
BigRich954RR's Avatar
Go with the Trickflow 245 heads very nice and Brian Tooley at TEA. Is a great guy he really helped me out
