Shawn @ VA Speed
06-18-2009, 06:43 PM
Virginia Speed Inc.
Fireball Special
http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures3-26-09040.jpg
http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures3-26-09039.jpg
Due to overwhelming interest we have decided to sell the same LS2 engine combination as in Brian Krezwinski's(Fireball)Trans am.This is the same exact engine but with a couple of additions for reliability.This engine is capable of handling 1600hp with no issues.But keep in mind,this is a race only engine-NO STREET USE.
Coupled with a 98mm turbo this engine has pushed Brian's 3500lb radial tire car to low low 8's at over 180mph in the 1/4 mile.
LS2 aluminum block with thick wall sleeves
Callies Magnum Crankshaft
Grp aluminum rods
JE pistons
Total seal stainless rings
Clevite bearings
Billet Main caps
Performance Inductions heads(formerly ETP)
VSI custom camshaft
Crower solid roller lifters
T&D shaft rockers
VSI custom double oring head gasket setup
Moroso oil pan
Melling oil pump
ARP fasteners
ATI balancer
Edelbrock Super Victor Intake
Chevrolet Valve covers
$18750.00
Options
6 bolt cylinder heads & block +$1000.00
VSI main support system +$600.00
Displacement up to 427cid is available but only with 6 bolt head and main support options at no extra charge
Fireball Special
Grp aluminum rods
JE pistons
Clevite bearings
Billet Main caps
VSI custom camshaft
T&D shaft rockers
Moroso oil pan
Melling oil pump
ARP fasteners
ATI balancer
$18750.00
Options
