LS7 Valvetrain/Cam
LS7 Valvetrain/Cam
Sorry for making another thread but I wanted everyones mind around this subject!!!
I am SUPER scared of my LS7 Failing on me.....
Which Valvetrain set up should I buy? Show me the money....
I am going to get LG Super Pro's + some sort of cam
But I want the SICKEST valvestrain....
Moderator
I would just grab Patriot duals. I have seen Katech go on and on about the stock rockers being fine since they have had zero failures unless yours is an 07. Personally, I would still grab aftermarket rockers myself.
Just be sure you have a sorted tune, there have been a few with piston failures that have destroyed the block.
This is advice I will be using shortly myself though I will be doing an entirly new topend.
U want reliability or do u want 7200rpm w/ hyd. roller? I have found that often they are not the same thing. The thing I see that causes the failure more often than not is the intake rocker bearing retainer. It is hardened steel, and fails spitting the needle bearings into the cankcase.(I believe it's the side-loading because it is off-set) When this happens, the rocker tries to open the valve via the retainer and not the stem, resulting in violation of the space-time continuum by the intake valve. The only shaft rocker I have tried are the crower stainless units I have run for close to 3 years now, but they have a good bit of mass and may cost a couple rpms. The failure rate of the stock rockers is low, but if u get crazy w/ the spring pressure I would worry. I think yella-terra and/or jesel has something by now.
I should have the Cam installed in the next week or so
O YA, I have never driven a C6....
I'm scared...NOT
LOL> I guess I do go on and on. The question gets asked a lot so I try to answer it a lot.
I thought the LS7 valves and springs were good pieces.
Also people have been racing their Vettes for years and now ZO6's come with a dry sump that hold 10 quarts of oil and it is not good enough?
Arent these engines good enough to race as they are? Maybe add headers and a slightly larger cam. 535 RWHP should suffice for most, any more power and the fun deminishes due to no traction. I had a big HP Vette and it was no fun, this 500 HP car is way more fun.
But I want the SICKEST valvetrain....
However, if money isn't a concern, how about these? Thery are steel, have no bearings and the black is NOT black oxide. It's DLC.
They would probably be the single most expensive system on your engine. Under 100 gm with adjuster, so knock off about 15 gm for non-adjustable hydraulic use. Your choice of ratio, of course since they are custom for your installation.
The pic is of a LS7 installation with the center rocker the offset intake.
No, they are not Jesel, nor T&D or any other brand you would recognize. These are big-time overkill for your engine, but you asked.
Jon
__________________
If you want good lifters try the GM/Caddy lifter (claims good to 8500) - I have over 30000 miles on a set, no issues so far
Also, COMP has some new LS lifters that are better for high rpm stability, probably along the same lines as the caddy ones..
I, too like stock rockers, perhaps with trunnion bearing upgrades. AFAIK, there are no roller-tipped rockers that are stiffer, lighter and with less Mass Moment Of Inertia than stockers.
Jon
__________________
Jon
__________________
