Alternator Removal LS-1
Please take me through the steps of removing the alternator on my '02 Z-28.
The diodes are going and I need to take the alternator to the repair shop. thanks.
Alternator Removal 5.7L
If you have the use of a lift, that is the way to go. If not, get the front of the car off the ground enough to have room to move around. Be sure to use a good pair of jack stands and I even left my floor jack under there too.
You'll need a 13mm and a 15mm socket on a 1/4 inch drive.
Remove the negative cable from the battery.
Release tension on the belt by moving the tensioner towards the driver's side
and while keeping pressure on the wrench remove the belt from the tensioner.
From under the car remove the plug that is in the top of the alternator. It clips in and you will feel a U type slot back there where you release it. It only has ONE VERY SMALL RED WIRE in the plug and will break easily if you forget to remove it.
Remove the rubber boot off the back of the alternator and take off the 13mm nut. Remove the cable.
The alternator is held in place by 2 long 15mm bolts and one 13mm bolt in the back. The center bolt in the bracket is the ONLY bolt that does not go through the alternator. If you take it out first get ready to duck.
With bolts removed you have to fish the alternator out.
I'll take my alternator to the repair shop in the morning to be rebuilt by the pro's. Hopefully the install will be a no brainer.
While you have it in the air......change the oil and filter and check all your tranny lines. I found the lower transmission line going to the radiator was rubbing on the sway bar. It almost rubbed through it.
Good luck.
Good luck.
I've had mine removed from the bracket to be able to access the driver's motor mount, but I could never figure out how to completely remove it from the car. How the hell do you get it between the sway bar and cooling fans? This isn't a pressing matter, I'd just like to know for future reference.
You'd better paint it or powdercoat it, because glass-beading the case will make it VERY easy to leave fingerprints and even corrode. Most rebuilding shops (like mine) use a steel-shot blaster to make steel and aluminum parts look like brand new, with little to no fingerprinting to stick to them.
Russ
Is your alt. from a 98-02 LS1 F-body?
Darn Gravity!!
I just picked up my alternator from the shop. He replaced the diodes with a much better quality one than what was in there. $45.00 and i'm ready to install it. I hope it goes back easier than it came out.
I'm sure there are others on this forum that can give a better explanation than me.
Once the alternator is out of the bracket and the bracket removed it should come out without any problem. Taking alt. and bracket as one unit is a little tricky. I had to rotate it the unit upside down to finally get it past the fan motor. But the alternator fell out of the bracket and smacked me in the face.
Darn Gravity!!
Darn Gravity!!
Anyways...so you're saying in order to remove the Alternator, you must also remove the bracket in which its mounted. And then with a little creative contorting, it will come out the bottom, past the driverside cooling fan. Is this what you're saying or have I read this completely bass ackwards?
Unless you drop the sway bar I don't see any other way of removing the alternator easily. Once you get the 3 bolts out that hold the alternator to the bracket you've only got the center bolt left that holds the bracket to the car.
I installed my bracket and alternator last night and it was a pain in the butt. I put...not installed...the bracket up first and then with the other hand worked the alternator up in position. Then I wrangled the bracket around the alternato and installed the backside bolt through the bracket into the alternator to keep it one piece. It is good at this point to try and plug in the plug. Next just line up the bracket with the 3 bolt holes, install the bolts and go get a beer. By this time you've earned it. Like I said earlier......I think the whole key to this deal is dropping the sway bar.
And, yes. By this time, you have definitely earned a beer. LOL. Thanks fbody396.
