The LSx 102mm LS7 Intakes Are In Stock @ TSP!!!
Old 06-19-2009, 10:23 AM
Jon@Texas-Speed's Avatar
Default The LSx 102mm LS7 Intakes Are In Stock @ TSP!!!
Guys we just received a few of the LS7 Fast 102mm intakes here at TSP!! Here's the info & link to order!!
http://www.texas-speed.com/shop/item...=1018&catid=20
Testing on a modified LS7 engine with a Big Mouth 102mm Throttle Body™ produced gains of 31.3 horsepower and 26.6 ft/lbs of torque at the flywheel over the stock intake!!!
Constructed from the same advanced polymer material as the LSX™ 92mm Intake Manifold, the LSXR™ offers a host of benefits over aluminum aftermarket intakes, including lighter weight, increased strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows the use of factory accessories without modification or clearance concerns
Old 06-25-2009, 01:36 PM
Another 10 showed up this morning guys!
Old 06-25-2009, 05:43 PM
longrange4u's Avatar
Cost??
Old 06-25-2009, 05:46 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Sorry, he gave a dead link.
http://www.texas-speed.com/shop/item...=1018&catid=73
$979 plus shipping!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-28-2009, 06:23 PM
Black02SS's Avatar
Any testing done on this? I have seen it tested by a few other shops, but there's not a lot of info out there yet.
Old 06-29-2009, 10:31 AM
We've got it slated to be tested on one of our Z06's very soon! We're confident that it'll show nice gains over the factory LS7 manifold!
__________________
