New LS1 Owners - Newbie Tech - what does this mean???
00TAM6
06-19-2009, 10:25 PM
I was trying to parallel park my car and I tried putting my car in reverse and it grinded. I put it in nuetral and put it in reverse again and it grinded again. That was the first and hopefully last time it happened. I drove around the block and I put it reverse again and it seemed fine.. What does that mean??? Need help.. Any suggestions/opinions??
HTh3r0
06-21-2009, 04:25 PM
when you come to a complete stop before you put it in reverse put it in 1st gear then go to reverse.
. . .worked on all my hondas. haha.
no grinds. I think it has something to do with lining up synchros or something.
rufrntn
06-21-2009, 04:34 PM
same thing happened in my firebird. i preferred 4th then reverse.
99345hp
06-21-2009, 04:51 PM
do as above, or just try putting the trans in neutral and letting out of the clutch. Then push in the clutch and try reverse again. The gears were probably just having a hard time meshing for some reason.
406malibu
06-21-2009, 04:55 PM
same as your other thread (exact same.... in the same section...) its bad syncros most likely.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
