purchased Ashtray Switch plate and want help for installation
Old 06-19-2009, 11:33 PM
PONTIAC SLP's Avatar
Default purchased Ashtray Switch plate and want help for installation
Hi , i made my custom ASP via a sponsor here emblempros , any one here have the diagram or instructions for wiring for nitrous , heater and purge ?
thanks in advance, Mohammed.
Old 06-20-2009, 11:35 PM
no one here have the diagram for my setup ?
Old 06-21-2009, 08:26 AM
Beer99C5's Avatar
Not enough information. Are you using a window Switch? If so which model?
In most cases the components you have for your system should have come with instructions and wiring diagrams. Line Loc and Purge are pretty straight forward and do not need a relay. Most switches are three lug and have on them Ground/Acc/+ marked on or near the lugs), the Purge Switch guessing is a spring loaded two lug switch. The Opener Switch you need the pinouts from the vendor (six lugs on the back of the opener switch?).
Old 06-21-2009, 09:49 AM
nikon1999's Avatar
the nitrous wiring section on here pretty much has every combination you may have.
Old 06-21-2009, 11:46 AM
look at this thread and give me your opinion https://ls1tech.com/forums/nitrous-o...m-correct.html
Quick Reply: purchased Ashtray Switch plate and want help for installation
