Old 05-27-2016, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
How are nittos NT555 for tread life
Old 06-20-2009, 08:18 PM
Smoke Em's Avatar
Default How are nittos NT555 for tread life
how are nittos NT555 with tread life???
both nitto nt555 and 555R
Old 06-20-2009, 08:20 PM
Mean87SS's Avatar
Kind of a loaded question...
Normal driving, ~15k miles on a 555R's
Old 06-20-2009, 08:23 PM
Smoke Em's Avatar
what about non drag radials
Old 06-20-2009, 10:43 PM
BobDoLe's Avatar
well...
the 555R has a treadwear rating of 100 and the regular old 555 has a rating of 300
Originally Posted by tirerack.com
UTQG Treadwear Grades are based on actual road use in which the test tire is run in a vehicle convoy along with standardized Course Monitoring Tires. The vehicle repeatedly runs a prescribed 400-mile test loop in West Texas for a total of 7,200 miles. The vehicle can have its alignment set, air pressure checked and tires rotated every 800 miles. The test tire's and the Monitoring Tire's wear are measured during and at the conclusion of the test. The tire manufacturers then assign a Treadwear Grade based on the observed wear rates. The Course Monitoring Tire is assigned a grade and the test tire receives a grade indicating its relative treadwear. A grade of 100 would indicate that the tire tread would last as long as the test tire, 200 would indicate the tread would last twice as long, 300 would indicate three times as long, etc.
so i'd guess around 7-8,000 miles on the 555R and 20-25,000 miles on the 555.
then again, people say they get 10,000+ miles on 555r. i think its safe to say the 555 should last 3x as long as the 555R
Old 06-20-2009, 10:52 PM
7camaro7's Avatar
I have 555s and they're everlasting! I do burnouts and race on them drive on them... They literally last for a very long time and are above decent with respect to traction.
Old 06-20-2009, 11:17 PM
milleniumvette's Avatar
Off hand, I couldn't tell you the miles on my 555s, plenty though for sure. But they've been on for near three years and look as new as the day I got them.
Old 06-21-2009, 07:17 PM
WhiplashDVD's Avatar
i got about 15k also on my first set of 555r's in the rear. They were basically slicks when i was done. The wear markers didnt even show. Many burn outs too
Old 06-21-2009, 07:58 PM
Smoke Em's Avatar
are the 285's noticeably narrower than goodyear 285 f1
Old 06-21-2009, 09:46 PM
superfreakws6's Avatar
Man I got probably 60,000 miles out of my nittos. They were extremes, and I did not tear the **** out of them. When I took them off they were slicks down to the bone, but for some reason tires last a really long time with me. Maybe it's because I don't change them until it is dangerous?
Old 06-21-2009, 10:34 PM
Smoke Em's Avatar
is there a difference between 285/40/17 and P285/40/17 nittos
Old 06-21-2009, 11:17 PM
BobDoLe's Avatar
regular old nitto 555 tires are 11.38" wide and goodyear f1 gs d3 are 11.4"
so i'm gonna say no
Old 06-22-2009, 01:30 AM
tspence45's Avatar
I also got close to 15k out of mine, maybe 12-13k. I even had a few different trips to the track, and a lot of spirited driving on them. Hell, they could've lasted a little longer, but I had them slightly over-inflated, and the centers wore out faster than the outer part of the tread.
Old 06-22-2009, 02:45 AM
96RamAirTA's Avatar
ive had mine on for well over 15k with countless burn outs and 1/4 mile passes and still not to the wear bar.
Old 06-22-2009, 11:51 AM
3.8redbird's Avatar
picks of the 555rs?
they are what I want next
whats the tallest sidewall they come in?
315/35-45/17 is what I need. higher the better.
Old 06-22-2009, 12:03 PM
tspence45's Avatar
Originally Posted by 3.8redbird
picks of the 555rs?
I think you can only get them in a 315/35/17. Here's a couple shots of mine when I first got them on.
Old 06-22-2009, 12:06 PM
3.8redbird's Avatar
thanks they look good. Gotta get spacers for the vette then gonna get me some of them.
Whose a good dealer to order from?
and price?
Old 06-22-2009, 12:33 PM
tspence45's Avatar
I got mine from DiscountTireDirect. It was $340 shipped for the pair. That was the cheapest I found at the time. (Back in December)
Old 06-22-2009, 12:36 PM
shaun's Avatar
i got mine from discounttire.com(a sponsor) and i got about 5k on mine and there still like new.
i have run em at the track a lot and i do a decent burn out each pass(they need a good burn out to heat them up so they will hook)
they have been wearing even and i keep em at about 28 psi for the street and ill go down to 20-22 depending on track conditions.
they do run a bit narrow tho.
Old 06-22-2009, 12:41 PM
3.8redbird's Avatar
can you explain this?
Old 06-22-2009, 12:56 PM
RsSean's Avatar
I hate mine, I have the 555's I don't like them what so ever. To hard and traction sucks. I have put a lil over 8k and they are still 7- 8/32 of thread.
Quick Reply: How are nittos NT555 for tread life
