Drag Racing Tech
6.0l 427?
Old 06-20-2009, 11:25 PM
StreetSilverado's Avatar
Default 6.0l 427?
Anyone else run this kind of CI?
6.0L block, 4.125 crank, .060 bore? Any luck for a NA set-up? Looking to go this route for a bracket car and index racing.
Old 06-22-2009, 06:01 PM
cbra-klla's Avatar
If it is just index and bracket racing why run so big of a bore and stroke? I'd save some to bore later on the next rebuild.
Old 06-23-2009, 08:42 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I ran something like that about 9 years ago, an ARE 422ci iron block. 4.060 bore and 4.080 stroke or something like that. Went 11.02@123 @ 3600 raceweight. With what I know today I could get that same car to go about 10.6 with the same level of streetability I had back then.
Old 06-24-2009, 11:44 AM
Bryan @ Speed Inc.'s Avatar
if you wanted a combo like that, and were using it for bracket racing - i'd just use a .030" over bore. displacement would end up at 421 cubic inches.
there are a handful of guys running 9's on motor with that block/bore/stroke combo.
Old 06-24-2009, 01:01 PM
Can you give me more info on a 421 build? cam, heads, intake, gears, converter, etc?
Old 06-24-2009, 01:58 PM
What issue will I have with a 4.125 stroke .030 bore on a little nitrous? 150-200shot.
