Replacing my transmission, question about converter.
Old 06-21-2009, 12:57 AM
whytryz28's Avatar
Default Replacing my transmission, question about converter.
Just bought a yank that killed my trans, the fluid has a nice dark tint to it. When I remove my trans and the converter do i need to empty and refill the converter or just check the fluid level and install it on the new trans?
Thank you guys.
Old 06-21-2009, 01:14 AM
LCplmarine98's Avatar
I would drain it and refil it jsut to be safe.
Old 06-21-2009, 01:17 AM
whytryz28's Avatar
So I just tip the bastard over to get everything out?
Or do I need to hold it a special way like those stupid glass ketchup bottles?
Old 06-21-2009, 12:13 PM
heymoej's Avatar
heads up.
if you have debris in your blown trans you better have your verter cut & cleaned or it will take out your new trans .........
Old 06-21-2009, 04:27 PM
dnkynrbk's Avatar
yea agree. Some tranny shops will clean it and flush it. Do that and then flush your tranny cooler to. To get all the debris out of it to. DONT TAKE ANY CHANCES
Old 06-21-2009, 05:13 PM
whytryz28's Avatar
Originally Posted by heymoej
heads up.
When i take it out, ill check the color of the fluid. Theres no chunks of anything just a slight tint to the fluid is all.
Old 06-21-2009, 06:10 PM
Badazz 97 TA's Avatar
i would also purchase a can of cooler line flush to clean out your lines and cooler. and get the converter cut opened and cleaned. There is no point in having contaminated fluid go through your new trans
Old 06-21-2009, 07:06 PM
NVR_SPDS's Avatar
You say your stall killed your trans? Do you not have a cooler installed with it? Just curious.
Flushing everything is the best idea, although I dont know if the stall can be effectivly flushed without sending it in for a cut and clean. IMHO, its not worth the risk of replacing your NEW trans just because the stall may not be clean. When i did mine, i just ordered a new stall with it, since i needed it ASAP.
Old 06-21-2009, 07:51 PM
heymoej's Avatar
what ever went out on your old trans will leave small particles in the verter from your old trans,it will still be in your verter & cause your new trans to take a shyt also.......
cut & clean by a reputable verter shop is your only option to get it super duper clean so it does not take out your new trans.........
Old 06-22-2009, 07:56 AM
Yank's Avatar
Sounds like the trans clutches went out and filled the converter with debris.
It would be best to send the converter in to be cleaned.
You can not get the trash out of the converter or clutch with out cutting it open
