Gen 5 Camaro Internal Engine Tech - Actual Weight Differences in SS cars
WILWAXU
06-21-2009, 03:22 AM
Curious what the actual weight difference are between 1SS strippers and full loaded 6sp manual cars and automatics.
I've already seen a loaded 6spd car tip the scales at over 4000 lbs raceweight. I'm guessing a loaded Auto would be heavier.
Anyone gathered that type of info yet?
jamnut
06-21-2009, 04:57 AM
From the looks of the stock exhaust you should be able to lose around 100# just by dropping the cats & big ass mufflers & going to a nice dual setup with smaller mufflers.
blk/slvr02ss
06-21-2009, 09:20 AM
I have seen 3849 lbs M6 and 3910 lbs A6 on Base model SS.
WILWAXU
06-28-2009, 02:59 AM
Good info, I'm more looking at the difference in trim levels.
How much less weight is a 1SS than a 2SS?
marcus769
06-29-2009, 12:26 AM
Ugh, thats heavy!
heymoej
06-29-2009, 10:13 AM
good question ,,,, :confused:
i am wondering the same....:D
ThunderZ28
06-29-2009, 12:33 PM
found this just a few minutes ago..
1EE37
LS Coupe
Capacities
Curb weight, 3780
manual, lbs.
Curb weight,
automatic, lbs. 3769
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EF37
1LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
automatic, lbs. 3750
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1EH37
2LT Coupe
Curb weight, 3741
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ES37
1SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
automatic, lbs. 3913
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
1ET37
2SS Coupe
Curb weight, 3860
manual, lbs.
Curb weight,
Cargo volume, 11.3
cu. ft.
Fuel capacity, 19
approximate,
gallon
Seating 2/2
capacity
(front/rear)
WILWAXU
06-29-2009, 02:34 PM
Interesting stuff.
So basically less than 100lbs.
Are those printed by GM?
ThunderZ28
06-29-2009, 03:18 PM
Interesting stuff.
Yep.. came out of their PDF file
WILWAXU
06-29-2009, 03:21 PM
Ahh, so actual weights my very ;) :D
UltraZLS1
06-29-2009, 03:34 PM
According to this the 1SS and 2SS weigh the same. Obviously not true.
damon_Z
06-29-2009, 07:35 PM
Ugh, thats heavy!
No doubt about it. Definitely not the ideal car for the dragstrip.
WILWAXU
06-29-2009, 11:19 PM
According to this the 1SS and 2SS weigh the same. Obviously not true.Yeah, missed that. I looked at the V6 and the 2SS.
Guess it will be a while before people start get serious about moding & racing these cars.
Dark SS
06-30-2009, 12:25 PM
1SS to 2SS shouldn't be much. The added electronics are mostly just programs in exsisting hardware like the radio and DIC, the 1SS has power seats too so it's just the weight of the leather and 4 pack gauges. The arylic dash and door panels maybe be lighter but that's made up with the added LED's. I would guess at or under 100# difference. The sunroof may add a few lbs. though but that's available on both.
WJ SOM SS
07-07-2009, 05:58 PM
My guess is once it's factored by NHRA, at probably F or G/stock, (stick) and G/SA (automatic), the raceweight may be at around 3800 w/a 165-70 lb. driver. It still remains to be seen, whether or not it'll be allowed to install a straight axle or make them keep the heavier, drag race-unfriendly IRS. Big problem there w/huge rear brakes for fitting lightweight smaller wheels and a real hooking tire.... Time will tell....a car this fast "looking" will definitely be made to go fast---no matter what the cost, by those who can afford to.....It surely would have made things a helluva lot easier, if they had offered a drag-pak option (50-100 build) like the Cobra Jet cars, w/a straight rear axle, rollbar, headers, good TB and tune, slicks and more....If the car sells real good, they just might follow Ford and offer something like that in the future...:nod: WJ
