Oil Pressure Question
Oil Pressure Question UPDATE And new question
Alright I finally got my car back together after the h/c swap and the first time I go to crank it up I have no oip pressure. So I tear it back down and discover that I put the spacer in upside down
We get it all back together and crank it up again and after about 5 secs I had pressure of about 40. Well we never got it to idle right so I get in today and when I cranked it up it took about 5 seconds but it still showed I had pressure. I get it to stay on go inside for a about 2 minutes and come back out and I have no pressure
What can be causing this I really hate to tear it back down for the 3rd time I just want to drive the damn thing(but aint till I have pressure of course).
But I'm going to let it sit for about 2 hours then go see what it does.
Maybe a coincidence the sender is on its way out too.....
From what I read they're known to take a dump....including the one thats on the motor I'm rebuilding now never worked....it read like 180psi
Well I let it sit for a few hours. Went and cranked it up and after about 10 seconds and still no pressure
The only thing I can remotely think that could have gone wrong is I put some paper towels in the pan to keep the bolt from fall in the pan but I'm 90-95% I took it out. How can I just drop the pan out to see if thats it. I sure as hell dont want to take the font end back off.
Or is there something else to check
Well its got a brand new sender and o ring (not that it couldnt be either).
I thought if the o ring was pinched it would show little or no pressure at all times but when I first cranked it up I had well over 40 then the next minute 0
Thats what making me think I left the damn rag in the pan and it is now clogged the pick up tube which is why I have no pressure
Course a rag in the pan could certainly do it...
Okay so I had a few minutes to work on the car before going out and I was in the process of getting all the bolts out of the pan and noticed I never tightend the bolt under the k member. Could this cause the lack of oil pressure? I had the rest down to factory torque and didnt notice any leaking so I dont think thats the cause but wanted to get some more opions on this.
Alright I took it apart and the ring is fine but I found pieces of the paper towels in there. So ill be dropping the pan tomorrow.
Sorry if the spelling and grammer is not right I'm on my blackberry
Alright guys after a long process I finally got the pan out and the pick up tube was blocked off by peices of paper towels
Good news is I got it all back together and she seems to be running fine. Sounds sick
So thanks for all the help guys.
I'll be uploading a video of it running and I'll post a link here.
http://www.youtube.com/watch?v=A8jPOXLfCcE
