t88 seized t4
Old 06-21-2009, 08:28 PM
cjg454ss's Avatar
Default t88 seized t4
has my pt88 take a dive and lock up today. cold side bearing is seized up. is their any wheel thats larger than 88mm that i can get swapped in. any options to get more power out of is. its on a t4 flange.
also could a 370 spool twin 88s, its a track car?
whats a typical rebuild cost?
Old 06-21-2009, 10:18 PM
Super Slow SS's Avatar
Sorry to make the first post a question and not an answer to any of your questions .. but is this a front mount and did you use an oil restricter?
Old 06-22-2009, 06:28 AM
cjg454ss's Avatar
no restricter front mount
Old 06-22-2009, 06:59 AM
Fireball's Avatar
370 is kinda small for twin 88s...
the guys at forced inductions should be able to tell you if you can swap in a larger wheel, but the t4 is probably restricting that since extra flow produces extra exhaust
Old 06-22-2009, 07:04 AM
smokinHawk's Avatar
i know forced inductions looked at putting bigger wheels in there, not sure if they went into production with it, dont thing the gains were that much though.
Old 06-22-2009, 07:39 AM
cjg454ss's Avatar
yeah i think i may just hack off the t4 flange and go with the t6. twin 88s would be sweet though, think a 410-434cu lsx could spool them
Old 06-22-2009, 07:43 AM
52172's Avatar
**** yea it would. I have a friend running twin 88's on a 408 spools great.
Old 06-22-2009, 08:08 AM
cjg454ss's Avatar
what kinda power does it make, ??
Old 06-22-2009, 08:17 AM
Fireball's Avatar
do you really have to ask that
Old 06-22-2009, 08:30 AM
cjg454ss's Avatar
their always low boost fireball, something you dont know about... lol j/k
Old 06-22-2009, 08:35 AM
Fireball's Avatar
don't even consider low boost on twin 88s....you'll be in compressor surge city
Old 06-22-2009, 09:10 AM
cjg454ss's Avatar
15-20psi is what i was thinking.
Old 06-22-2009, 09:18 AM
Fireball's Avatar
thats not low boost
why bother with twin 88s unless you are trying to run 30+ psi on a big motor?
twin 76s would be a much better fit
Old 06-22-2009, 09:45 AM
cjg454ss's Avatar
thats not low boost
i already got one 88, eventually im thinking twin 88s with 25psi but i need to have a car that can support that. i think twin 88s on a 408 or so would puk 1k to the ground @ 15psi
Old 06-22-2009, 02:44 PM
LS1TECH Sponsor
DrTurbo's Avatar
The compressor cover on those units is already about max with an 88mm wheel and the T4 turbine housing on that turbine wheel is maxed.
Old 06-22-2009, 02:47 PM
cjg454ss's Avatar
the larger cover help much?
Old 06-22-2009, 05:41 PM
MIGHTYMOUSE's Avatar
i better be the first to know about the pte-88+3 or whatever it is/was/will be... my foot is soo tired of tapping!
cjg, if you are at 120 in 6.2 seconds then there is more left in your current set up before doubling up fo sho.
Old 07-03-2009, 10:20 AM
blacksi's Avatar
Damn, not one price ;mentioned.
Old 07-03-2009, 10:54 AM
smokinHawk's Avatar
^cause its not released or available to the public
Old 07-10-2009, 08:14 AM
blacksi's Avatar
Let it be known Dr. Turbo does it for $250 assuming nothing besides basic rebuild parts are messed up.
Quick Reply: t88 seized t4
