I need this, whats it called?????
Old 06-22-2009, 01:23 AM
avengedws6's Avatar
Default I need this, whats it called?????
Dont worry Im posting this in the classifieds as well. I just dont know what the hell its called. I need on asap thats all I need to start my car.
Old 06-22-2009, 01:47 AM
16floz470ml's Avatar
evap solenoid
Old 06-22-2009, 01:52 AM
avengedws6's Avatar
Originally Posted by 16floz470ml
evap solenoid
I owe u a beer, Thank u.
Old 06-22-2009, 02:56 AM
avengedws6's Avatar
fuel evap silenoid am I right?:
Old 06-22-2009, 06:52 AM
built408's Avatar
evap purge solenoid. Just throw it in the trash and put a vacuum cap on the manifold.
Old 06-22-2009, 11:31 AM
strokerblackhawk's Avatar
so you can just cap the manifold and get rid of that thing?
Old 06-22-2009, 12:02 PM
built408's Avatar
yap, just delete the code
Old 06-22-2009, 12:48 PM
98silvertacrbn's Avatar
Don't you also need a small filter on the end of the hose near the gas tank so it don't suck trash when the fuel tank needs air or to vent
Old 06-22-2009, 01:23 PM
Don't listen to that guy. If you do this your fuel tank will vent fuel vapor under your hood. Not only could this prove flammable you will also be able to smell it. It could also keep you from passing inspection.
Old 06-22-2009, 04:39 PM
avengedws6's Avatar
thanks for all the help guys. I pmed ya chance on lsm. i just picked one up fron daniel at SQR.
Old 06-22-2009, 05:09 PM
built408's Avatar
If you cap off the hard line then you won't vent the vapor under the hood. And lets face it, 95% of people on this site don't have cats and could give 2 ***** about a passing an inspection legally. You take your cats off, your egr off, your air pump off, you might as well finish the job and take the purge solenoid off.
Old 06-23-2009, 01:34 AM
avengedws6's Avatar
rock on my man.
Old 06-23-2009, 12:44 PM
It is more like he has rocks in his head. When the fuel tanks builds up pressure what do you think happens when it can't release the pressure? It will vent it out the gas cap and sound like a submarine at crush depth. If the gas cap is bad and will not release pressure then your fuel tank will burst or maybe even explode. Some people.
Old 06-23-2009, 03:22 PM
built408's Avatar
You are apparently ignorant and have no clue on how the evap system works. So son, get your pen and paper out and let me school you... The PURGE solenoid, which is what we are talking about, is used to draw the vapor from evap canister, which is connected to the tank. There is also a VENT solenoid. The VENT solenoid is normally open, which means normally VENTING. During evap operation, the VENT solenoid will close, and the PURGE solenoid will open, drawing the unused vapor back into the intake manifold. So, if you take the PURGE solenoid off, the VENT solenoid is ALWAYS venting. So the tank will not build pressure. Learn how **** works before you start running your mouth!!
Old 06-23-2009, 03:31 PM
ramairracer's Avatar
burned!!
avengedws6's Avatar
Damn, Its ok. I got it running now. And I know im schooled on alot of **** after doing this.
Old 06-23-2009, 03:48 PM
built408's Avatar
Lol, I wasn't talking to you.
Old 06-23-2009, 03:56 PM
jermstyle's Avatar
Pretty much all of that crap can go. My intake only has items required to make power.
Old 06-23-2009, 03:58 PM
You are truly an idiot.
Old 06-23-2009, 04:24 PM
7420NW7TH's Avatar
I took my EVAP off also and plugged the lines. Really helps the appearance of the engine bay also. That was about 3 years ago, and it hasn't blown up yet, LOL. It WILL throw a code as pointed out, but you simply just turn the code off. Technically, they can fail it at inspection by doing a visual under the hood, but I've gotten mine inspected at least 3 times without it, and they haven't said anything yet.
