smallest procharger 8 rib pulley?
Old 06-22-2009, 04:58 PM
BoostedWS7's Avatar
Default smallest procharger 8 rib pulley?
i have a 3.70 now and making 11-12 lbs.(@7,000rpm) want to make 17lbs. possible?
im thinking i would need a pulley around or just under 3". do they make them? is there a setup that uses a bigger crank pulley? mine is 7.25 now...
searched but came up wit nothing!
Old 06-22-2009, 05:17 PM
BigRich954RR's Avatar
Get a bigger Crank pulley. I think your crank pulley is 7.5 inchs which is what comes on Fbody kits?
My GTO pulley was 7inch and i got a 8inch made took about 2weeks to get.
Old 06-22-2009, 08:36 PM
BoostedWS7's Avatar
nah mine is 7.25". guess thats the fix huh?
Old 06-22-2009, 08:59 PM
Its cost a little more to do a crank pulley, but it also helps with belt slip alot. But im running a F1C im not sure if people have issues with slipping on the D size ones though
Old 06-23-2009, 08:34 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I know that there is a 3.1" 8-rib pulley.
Old 06-23-2009, 10:17 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
Are you running the SDCE kit? If so, I think you are limited to 7.25. The stock procharger 8 rib crank pulley is 7.65". And to answer the original question, the smallest blower pulley I've ever heard of is 3.2", but there may be smaller ones. I would think 3.2" is just begging for belt slip tho!
Old 06-23-2009, 11:36 AM
'Trust''s Avatar
ProCharger doesn't make anything smaller than a 3.4" 8 rib, trust me, I've tried. If you want smaller you need a Reichard Racing pulley, but I can't speak for them since I'm still on the 3.4".
Old 06-23-2009, 11:38 AM
john_sblendorio's Avatar
as others have mentioned, you will be way better off changing the crank pulley
Old 06-23-2009, 01:51 PM
Forced370GTO's Avatar
i have a 3.4" 8-rib procharger pully im not using. pm me if your interested.
Old 06-23-2009, 02:53 PM
AFASTYZFR1's Avatar
I have been waiting for over 2 months for a reichard pulley
Old 06-23-2009, 07:14 PM
grpaic's Avatar
i have the same set up... i did go with a bigger crank balancer innovators west great belt wrap no slip...have a 4:00 8 rib pulley on it making 14p-15 pounds of boost...by the way if you are changing your pulley and want to sell the 3:70 let me know..
Old 06-23-2009, 08:34 PM
BoostedWS7's Avatar
what size is your crank pulley
Old 06-23-2009, 09:16 PM
SilverSS's Avatar
BoostedWS7 - I made 14-15psi with a 3.7 pulley. That was with a 7.65 crank pulley though. How much power is the car making?
grpaic - I have a 3.7 pulley if you need one.
Old 06-24-2009, 05:32 AM
grpaic's Avatar
its 10% overdrive 8:25
Old 06-24-2009, 05:34 AM
grpaic's Avatar
Originally Posted by silverss
boostedws7 - i made 14-15psi with a 3.7 pulley. That was with a 7.65 crank pulley though. How much power is the car making?
Grpaic - i have a 3.7 pulley if you need one.
is it a 8 rib ? For a pro charger? If yes i would thanks ahead of time...how much sipped to boston?
Old 06-24-2009, 09:26 AM
'Trust''s Avatar
Where can I get an 8.5" crank pulley?
Old 06-24-2009, 10:53 AM
LS1RedZ's Avatar
+1 I want more boost! I was thinking of going with a bigger crank pulley or getting this new tensioner setup this guy came out with. Its cheaper than SDCE too! WAY more belt wrap.
Old 06-24-2009, 01:43 PM
grpaic's Avatar
go on there website innovatorswest.com ......i think there about 6 bills
Old 06-24-2009, 05:32 PM
BoostedWS7's Avatar
soooo i think id need somewhere in the neighborhood of 7.75" cranck pulley. and im not goingthrough those innovatorswest.com guys for a custom. thats crack prices.
Old 06-24-2009, 05:48 PM
BoostedWS7's Avatar
just looked into it a lil further. i dont need the entire pulley that slides on to the crank. i have an ati damper so i just need just the pulley that bolts onto the face of the damper. my original setup is an sdce.
Quick Reply: smallest procharger 8 rib pulley?
