Custom Fiberglass Boxes?
Originally Posted by ALPINE
Man, if I can get them to do it in a 12, it'll be money. Thanks man!
There's your answer.
Well crap. I don't think I can get the low freq. response from 10s that I want. I'll have to look around some specs, any ideas guys on a 10 with will repond as low? Thanks again for the ideas.
Quote:
Originally Posted by firebirdude
http://subthump.com/acamarottop.htm
He said that he wants his ttop space back... not completely gone
The other one is way cool, but would requre me to move my amps and Xbox. Cowboy, I may just spring for the less refined one, mainly because I can keep my 12's. Much appreciated guys.
If you are looking for low frequency extension, you need to go with a ported design. In which case, with a pair of 12"s, I don't see you keeping your t-tops storage. Just get the biggest sealed box you can fit back there and still allow for t-top storage.
http://f1.pg.photos.yahoo.com/ph/ric...tos.yahoo.com/
two jl12w6v2's, no space lost, uses the empty space like a bandpass to produce low frequencies. The sound is not affected by the ttops in the back. However if I completely load up the back with luggage the low frequencies suffer.
How low of frequencies are we talking about here also? I can play really low (I haven't tested the track but competitors say it's 18 hz) and I have a 12" Brahma mounted on the drivers side free-air with 275ish watts going to it. When the low notes start playing it will vibrate you in your seat and it sounds sweet.
If you want a car to go low, and I mean like 20's and 30's low, you need a lot of displacemnt (talking cone movement and cone area.) the power to push the lower frequencies so that our ears can hear it, and a box set up that allows the woofers to do those lower frequencies to name a few of the basic things you need. You'd be amazed at how much a woofer has to move to do 20 Hz at the same volume as 30 Hz when comparing the two.
Now, if you are talking like rap music when they go low then they are most of the times in the 40's and 50's and sometimes dip into the 30's and on some systems either they will fall flat on their faces and just not produce the 30's or they will do it but you can tell it's struggling to do it. Then there are the guys with two 15's, plenty of power, and plenty of room in their SUV to give them a big box and they can rock'in roll into those lower frequencies! :-)
Most people aren't going to need 20's and 30's low though. So, if you like to rock on out to rock'en roll, alternative and rap lets say, the 20's and low to mid 30's shouldn't worry you too much anyways. Check into the Image Dynamics Id 12 V.3, it would probably work out nice in those enclosures that you are thinking of. Oh, and even if you put a sub in a smaller enclosure than it's designed for it doesn't mean it will sound like crap, it will choke the lower frequencies off and can also give you more of a hike in frequencies a little higher up but some people prefer that sound so its' a toss up if it will be what you are looking for or not. Either way, I've heard good things about Image Dynamics subs so from what I hear you can't go wrong with them.
I know, I'm all over the place in this message but it's close to 6:00 and I'm typing this up before I'm getting off of work here and getting ready to go home. Have a good one and if I wasn't clear about something, just ask and I'll clarify.
Ted
I've heard good things about Image Dynamics, especially their small box reqs.
What do you think of JL componets? I'm looking for bank for the buck here. I was thinking of running two seperate amps one for the front and one for the rears, becuse I'm not sure I'll even want to change the rear speakers at all, may just jam the front componets.
To the people asking about component sets I'd say your best bet would be to go and listen to some and hear which ones you like best.
There are going to be ones that sound better than others to me but it's what you like that's most important. Find places in your area to demo them at and bring along a good CD that you like (don't listen to radio) and listen away! :-)
I have heard good things about JL's upper end line of components but don't know what to say on their middle or lower line components.
On the Alpine deck question, don't know what to say on that, maybe somebody else knows more about Alpine's line of HU's and can answer that for you. Sorry, wish I could be of more help.
Ted
Ted
Ok, since we wanna get technical lol:
The 9811: $330
• 50W x 4 High Power Amplifier
• Bass Engine® Plus
- 4-Channel Digital Time Correction
- 3-Position HP/LP Digital Crossover
- Subwoofer Level Control with Phase Selector
- Bass Center Frequency Control
- Bass Band Width Adjustment
- Treble Center Frequency Control
- Bass Type Control
• Media Xpander™
• XM Satellite Radio Ready
• MP3/WMA/CD-R/RW Playback
• CD Text and MP3/WMA Tag Informtation Display
• Quick Search Function
• CD Text, CD Text Display, CD Text Scroll
• 3 Color Display with Output Level Indicator
• Versatile-Link™ Ready
• MaxTune SQ Tuner
• Regulated 1Bit DAC
• 3 PreOuts (4 volt)
• MM Driver (Hard Disc Drive) Ready
• MobileHub™ Ready
• Swing Mechanism with Detachable Face
• RUE-4187 Wireless Remote Control Included
The 9813: $400
• 60W x 4 V-Drive™ Amplifier
• Bass Engine® Pro
- 6-Channel Digital Time Correction
- 6-Position HP/LP (24dB/Octave) Digital Crossover
- 5-Band Parametric EQ
- 3-way or 2-way electronic crossover with adjustale slope
• MediaXpander™
• MaxTune SQ Tuner
• BlackOut Display
• MobileHub™ Ready
And SSTAR on the first lines of both sets of specs are the different pre-out levels, lemme know if you want any further explanation. Laters.
The 9811: $330
• Bass Engine® Plus
- Bass Type Control
• Media Xpander™
• MaxTune SQ Tuner
• MobileHub™ Ready
The 9813: $400
• Bass Engine® Pro
• MediaXpander™
• MaxTune SQ Tuner
• BlackOut Display
• MobileHub™ Ready
