92 or 92 ported?
92 or 92 ported?
okay so im going to have the setup of full bolt ons patriot stage 2 heads and a comp cam with lift in the low 590's and duration in the high 220's....im going with a 92/92 setup i was just wondering if i should get the ported 92 or just stick with the stock 92mm....the only reason i ask is i wasnt sure if the manifold was ported if that would be overkill or not...gonna be somewhere in the 420/400 power area....so ported 92 or regular 92?.... just dont want to be moving too much air?
