kooks header install on a 408....HELP!!!
Ive spent this whole afternoon trying to install my Kooks 1 7/8 headers on my 408. The passenger side went in no problem but now the drivers side is not going in no matter what. Ive tried the search and did all the methods people suggested other than major things. I havnt tried lowering the k-member or pulling up the motor. But I really dont want to do those things because ive spent the last few days getting them into place. I think part of the problem is getting the car high up enough to get the header in at the right angle. One guy was saying he just turned the flange to a 90* angle facing the ground and just shoved it up and into place but i cant seem to get that to work. It looks like you can get it in from the top if you take out the steering shaft. Im not sure how to take that out and i didnt want to break it. I also have Spohn solid motor mounts and nothing a but a bare longblock in the engine bay. It just seems like everyone has their own way of doing this and none of those methods are working for me.
What do you guys think?
Kleeborp the Moderator™
That must have been my post where I said you could turn it 90 degrees and get it up into place - keep in mind that when I say that, it is possible, but it does take some persuading to get it up there.
Removing the steering shaft isn't too bad...you should be able to see a couple of bolts. Loosen those, and it'll slip off.
Your not going to break that steering shaft. There is a bolt at the top and one of the bottom of the shaft. Both must be taken out then you can slide the shaft up and it will pop out. It will probably take a little persuasion with a hammer to get it to move. It's hard to explain exactly how to do it. But if you have gotten this far by yourself you can definately do this.
if your running a stock k member start with the header straight up and down in front of the hump that sticks out towards the oil pan. you should be able to go straight up then rotate in. i tried for a while before i figured out i needed to start in the front hole so to speak. good luck man
is the key here just to get the car up extremely high? I was trying this method but was still having trouble with ground clearance which is probably why i couldnt get it in.
high enough that you can get the header almost straight up and down in the hole. i used a set of truck jack stands. the bottom of the rocker panel was about 24" of the ground in the front and i had the back end up as well(about 18")
Did you already cut the little casting square off the block that sticks out just above the oil filter? Cutting that off with a cutoff wheel or sawzall will help you a ton. It's small, but it's in a pain-in-the-*** location.
I think i may have taken the 4 bolts out of my tranny crossmember and lowered the tranny down just a bit, enough to make the motor move and it was easier when i installed my tsp 1 7/8" headers
Ok i just cant do this. I have tried every possible way i can do and i just dig myself into a deeper hole. I really need somebody to come and help me with this. anybody in the chicago area available this week?
