oil filter relief check valve?
Old 06-23-2009, 06:47 AM
badmfkr's Avatar
Default oil filter relief check valve?
why do some oil filters have preasure release valves and others do not?
If I remeber corectly some imports require a preasureized relief valve becauce of where the oil fiter is mounted like high on the engine.
I'm thinking the spring actuated valve is like a priming at intial start up.
I'm wanting to replace a prema cool extrenal filter using as a extra trans. filter and it has the valve.
http://www.summitracing.com/parts/PRM-10675/
Thanks for any good feedback.
