Line pressure issue?
I have tried calling my tuner several times with no answer about this issue, but after I had my car tuned (by a very reputable tuner) I had the line pressure upped to make the shifts more aggressive and they feel great WOT, but after it has to hammer through a shift (downshift or up shift) the line pressure (I'm guessing) stays super high so it SLAMS into second under cruising conditions. Still shifts fine WOT! Fluid levels and temps are great! No major issues at all. When I turn the car off for more than a minute, shifts are incredibly smooth as long as I don't go WOT. I'm pretty understanding that this is a tuning issue, but what is causing this and how bad is it for my transmission?
Thanks,
Kyle
Thanks,
Kyle
My 2000 Silverado does the same thing. The transmission leans how you drive and can tell when there is a big load like a trailer, or a driver with a big grin. (: This slammed shift is very evident with elevated line pressure or a too hard of a shift kit in the 4l60e's. Prove it by stopping and shutting off the motor and upon restart it will revert back to the stock settings. There are better ways to do this than elevated line pressures. A correctly set up shift kit is likely a better set up for a daily driver. I know the part throttle shift to second is likely brutal after a full throttle blast.
