Car got egged
Car got egged
So sometime between 1AM to 5AM my car got egged. Luckliy I had just waxed that car on sunday so I know it won't do to much damage however I have some nice scratches right where the egg hit the drivers side door. The only problem is that I only got to wash the egg off around 11 this morning so it got to bake onto the car in the lovely florida heat. I have an idea who it was and plan on seeking revenge, however the revenge I plan on seeking isn't exactly leagal to do. Anyone know what the egg that I wasn't able to remove will end up doing to my paint and what I can semi-legally do to seek revenge?
Read through this thread, it should give you a couple ideas
https://ls1tech.com/forums/racers-lo...-back-him.html
brake fluid will eat through the paint or so ive heard also heard bologna does a number after it gets cooked in or also heard a bottle of trans fluid in the gas tank will do some fun things also
Sorry to hear Matt! Atleast you got it off. I always worry about that stuff. You know you have back up if you need it! Screw that using food crap..If I was doing revenge...paint stripper...spray it on and walk away. You can get creative and put words too. Tires are replacable....paint is forever.
If you have time, just remove all thiers tires and leave there **** on blocks. That would be great and harm less. Crack the bleeders on there brakes, so they have to bleed them bitches. You can use a small pry bar adn pry back the top of the windows and pour in a *** load of ants. Those guys will go to town in that car like it was a picnic. If you do that I want pics sent to me privatly. I think that would be the best ever
id say the aircraft stripper or brake fluid will work wonders orrip the valve stems out of there cr tires or take the oil drane plug out and drain the oil out
This is an oldie but a goodie:
Go buy a few big cans of shaving cream and freeze them, has to be the old school NON-gel type. Then in the middle of the night slim-jim their car door to gain access. Then cut the cans in half or pry the bottoms off if you can, this is when it starts to get messy. Once the shaving cream thaws it will expand and if you use enough and did it correct it will fill a lot of the interior with shaving cream.
LOL WOW there are lot of ruthless people here! I know what everyone means here, my car was egged about a year ago right after I got the berger panel done flat black. I was PISSSSED. It discolored it. Never found out who did it, took paint off my trunk and put a lot of nasty chips and scratches. Punks.... I worked in autoparts and yes brake fluid is the cheap easy way to go! It will eat the paint off. But that Aircraft Stripper someone else mentioned also works AWESOME....I used it on my wheels to eat the clearcoat off, it works FAST...It is an aresol can, you could just run by their car and spray as you go, quick, get er' done and run away!!!! haha...that would suck. And sorry, there isn't really any legal way to do anything....revenge never is.
take an old antenna from a car and snap it on a window.. or get some old spark plugs, smash off all the ceramic and toss em at the windows.. it'll give the windows a nice "textured" look so to speak
