Fueling & Injection - Me Wan Buy Racetronix Pump
View Full Version : Me Wan Buy Racetronix Pump
dancrosoft
06-23-2009, 12:05 PM
I got 2000 Z28 that needs a new fuel pump. Stock application/noting fancy. Just want a good pump. Can someone throw up a link to the pump they sell that will be plug and play? I think it was the one for like 150 bucks or so.
The one I found with my goooooooogle was : http://www.racetronix.biz/itemdesc.asp?ic=FPA-001&eq=&Tp=
Nasty N8
06-23-2009, 12:24 PM
Thats the pump you want but you want to do the wireharness along with it the higher amp draw of the new pump can damage your stock wiring. I keep a couple options in stock give me a call.
Nate
dancrosoft
06-23-2009, 01:00 PM
The Racetronix dude said it is plug and play??
http://www.ls1tech.com/forums/general-maintenance-repairs/1130610-time-new-fuel-pump-one-best.html
slow
06-23-2009, 01:04 PM
you just need to select the add on harness on the upper right of that page.
Ryan
dancrosoft
06-23-2009, 01:14 PM
Ryan
I understand what you mean but according to the Racetronix dude here: http://www.ls1tech.com/forums/general-maintenance-repairs/1130610-time-new-fuel-pump-one-best.html only the pump is needed for a stock application?
SMOKNSS
06-23-2009, 02:18 PM
Yes all you NEED is the pump, but just like Nate said you will need the hot wire kit for the aftermarket pump so that it will not damage the factory wiring. You can chose just to buy the pump and take your chances. He's just sharing his experience/knowledge.
dancrosoft
06-23-2009, 02:24 PM
Hmm. Well in that case I will not be buying this pump. I need a pump that will work with factory wiring. I see no use in my case to use a pump that will require me to redo any wiring.
dancrosoft
06-23-2009, 02:31 PM
http://www.racetronix.biz/itemdesc.asp?ic=FPA-002&eq=&Tp= < this is the pump I need :)
MeentSS02
06-23-2009, 04:16 PM
The stock pump works with factory wiring.
A higher capacity fuel pump is more than likely gonna require more juice to run, and the stock wiring is marginal at best. If you are going to the trouble of replacing the fuel pump, how much more trouble is changing the wiring harness? It is plug and play just like the pump...
dancrosoft
06-24-2009, 12:02 PM
I see your argument... How much more work is it compared to just cutting a hole in the back and pulling one out and putting another in?
t/a98
06-24-2009, 12:06 PM
plug it in to the alternator, zip tie it to the frame, unplug harness infront of rear axle, plug in racetronix, thats about it.
