Belt for P1SC
Old 06-23-2009, 02:48 PM
Ryan33187's Avatar
Default Belt for P1SC
What kinda of belt is normally used on the P1SC I believe I have the stock pulley
Old 06-23-2009, 02:58 PM
'Trust''s Avatar
Depending on your blower pulley and crank pulley size it could be anything. What pullies do you have?
Old 06-23-2009, 03:00 PM
Ryan33187's Avatar
Ill measure them when I get back from work tonight I'm not positive bought a used kit. Also if I only want to run around 8 psi what size pulleys should I be running?
Old 06-23-2009, 03:46 PM
'Trust''s Avatar
Assuming you're on the stock CI, probably a 4" pulley, depending on your crank pulley size. I'm not sure on P1's though.
Old 06-23-2009, 04:21 PM
Zeke34's Avatar
Default Procharger Belt Sizes
Below are a few links that'll should help you out with finding the right belt for your setup. I hope these help...
https://ls1tech.com/forums/forced-in...lt-needed.html
http://www.exoticperformanceplus.com...html?item=1041
Old 06-23-2009, 08:57 PM
Ryan33187's Avatar
I have a 6" crank pulley and a 4.5" blower pulley (6 rib). Ya stock LS1 besides a TR Blower cam, springs, timing chain, pushrods, oil pumps, and such... What kind of boost do you think it will be pushing? I don't want to go over 10psi id like to be 8-10psi. Looks like the impeller is gonna be going about 32k RPMS. Which is about half the max so would I be safe to assume I'm in that range?
Old 06-24-2009, 12:31 AM
Zeke34's Avatar
Sorry I don't know how much boost you'll end up with but if you aren't able to find your answer through search then your best bet would be to contact Bob @ EPP. Also, below is a link for information on the 6 rib belt sizes.
http://www.exoticperformanceplus.com...html?item=1037
Old 06-24-2009, 03:06 AM
Ryan33187's Avatar
Thanks for the info on the belt size!
Old 06-24-2009, 04:28 AM
EPP
EPP's Avatar
Back in '02 I had a 110,000 mile internally stock LS1 with headers and exhaust. We installed a six rib (all that was available at the time) D-1SC kit. 6.0 crank pulley and a 4.0 blower pulley gave it 7 psi. The D-1SC typically makes one to 2 more psi of boost with any given blower pulley than the P-1SC does. With your cam I'd say you are going to need a 3.60 pulley with your P-1SC. Bob
Old 06-24-2009, 10:35 AM
Ryan33187's Avatar
Ok, also the FMU that comes with the kit do I need to install that also if I'm putting a walbro 255 fuel pump?
Old 06-24-2009, 10:53 AM
EPP
EPP's Avatar
The kit that I have the above link to does not come with an FMU. An FMU stands for fuel management unit and is not used if you are using larger injectors and getting the computer recalibrated. Bob
Old 06-24-2009, 01:14 PM
Ryan33187's Avatar
Hey Bob, Where could I pick up a pulley of that size on the fly? Do you guys carry them in stock?
Old 06-24-2009, 01:21 PM
EPP
EPP's Avatar
Yes, we have most of them in stock $85.00. Thanks. Bob
Quick Reply: Belt for P1SC
