If I hit the rev limiter under boost will it blow?
I just got my custom turbo truck tuned today. The tuner told me if I hit the revlimiter under boost, it will cut fuel and prob blow the motor, is this true? If so how do I prevent this from happen?
I blew my motor hitting the rev limiter or at least that's the only reason I can think of that it blew. Boost was at 16psi with 100% meth still spraying when the fuel cut-off kicked in @7K due breaking traction. Cracked a cylinder. Don't know if hitting the rev limiter was the actual cause but im gonna raise the limiter past 7k in my new motor once it gets tuned.
Another reason I don't run that crap.
7 Second Club
As long as you are not using another fuel adder like a meth kit or anything else that is adding fuel like a wet nitrous kit than no you will not blow your motor by hitting the rev limiter. The factory computer cuts all fuel going in to each cylinder as necessary, not half or anything other amount so it will not run lean.
