Fueling & Injection - What's the Deal with my Fuel Pressure??
Trev_SS
06-24-2009, 01:37 AM
Ok so for a while I have been having a little trouble getting my car to start. It cranks over for a while before it will actually start. Sometimes I have to try it like 4 times before it starts. I finally started to take a look at things and I hooked a fuel pressure guage up to the fuel rail and ran it under the hood. I go to start it and the pressure slowly starts to build up each time it starts to crank over. When it finally gets high enough it will take of and start up. I need to know what to look for is there a relay that could have gone bad or is it just time for a new fuel pump with hotwire kit. I need to get this fix asap. Thanks for all the help and I have tried to search it brings up nothing useful.
PoorMan
06-24-2009, 10:48 AM
I would change the fuel filter first if it have never been changed.
Trev_SS
06-25-2009, 01:41 PM
I have already changed the fuel filter that didn't help. I believe that I am going to have to replace the pump. after some reading I am pretty sure that the fuel pressure regulator is going and that is why it doesn't hold pressure.
marv20052001
07-17-2009, 12:43 PM
I'm havin the same problem. Was it the pump?
Lonnies Performance
07-17-2009, 07:59 PM
I'm sure I can diagnose your problem.
Feel free to call me for more info. I can be reached at 724-322-8505 from 9:00am-11:00pm eastern time, including weekends.
__________________
LS1Fury!
07-20-2009, 08:36 PM
Another person having the same problem :( I changed the relay today and it worked for about half an hour before it started having troubles starting again.
