pressure port an acurate place to measure trans temp
ive got my tranny temp sensor tapped into the pressure port on my 4l60 and im wondering how accurate it is. the heat in houston is friggin brutal, its supposed to hit 101* tomorrow, my tranns runs pretty hot even with the hayden cooler if im not on the freeway.
if the gauge is correct then its time for some changes, im not about to roast a brand new tranns. cooler weather it was never a problem, now its hot outside at 2 am.
nope i would recommend only in the pan the pressure port usually reads about 20* higher i live in FL and in traffic it gets to maybe 165 to 170 with A/C on and freeway about 140 but i also have the biggest B&M cooler available so that may also help alot
I have a guage in the PP and an aerospace guage that reads through the computer. I feel it is accurate BUT when the temp fluxuates the pp is slow to respond. Like if you make a pass at the track it won't go up much right away. It will take a few minutes but it will get there.
My own theory is it reads the trans case more than the fluid. But i also put teflon tape on my sensor and that maybe be hurting this too.
I think the gauge you are referring to in an Aeroforce Interceptor. It is a great gauge and does not require a sensor to read transmission temp, it pulls that info. right from the OBDII port.
