trans. fuild change ? on TC fuild
I would like to get as much fuild out as possible.
if I leave the drain plug out on my deep TCI pan over night will the torque converter fuild drain out?
it's been about an hour since drain plug removal and it is still dripping.
Thanks
Thanks
Nope....think of it as a tire off the rim standing up with water in it. The donut like shape of the verter will still retain most of the fluid even if you hold it upside down.
draining fuild
so far I've estimated 8 quarts drained. please consider 2 trans. coolers (20K + 24K) and a external filter.
Thanks
No. The shaft that supplies fluid to the converter is in the middle. Any fluid below the middle of the converter has no way out. Even when removed, they are like oil filters, no matter how many times you turn them over it seems like there's always fluid inside.
