Burkhart's Dog Days of Summer Sale
LS1TECH Sponsor
We will be giving away a free puppy with every order of 1000.00 or more.
OK Here is the part where I screwed up to your advantage. The 6 point should be 950.00 installed or in kit form. We will do 3 installs and 3 kits at that price. It is 1st come 1st served.
Hah, just kidding. What would YOU like to see on sale? Ask and all reasonable requests will be considered. As you ask I will post up in here for other members to see.
Aerospace Brakes
https://ls1tech.com/forums/drag-raci...rake-sale.html
HVAC - 53.00
Master with Lineloc - 312.00 add a brace for 38.00
Manual Master no line loc - 188.00
ABS Delete Kit - 272.00
6 point CM bar installed 620.00
Front drop spindles - 525.00 Just spindles
With Aerospace brakes 1075.00
With Strange brakes 1199.00
Bumper support LS1 TA and Camaro - 217.00 Bare add 25.00 for PC
LT1 support 307.00 add 25.00 for PC
Adjustable TA - Standard 375.00 Extreem Duty 435.00 add the DSL for 54.00
Front suspension kit (K Member, uppers and lowers, rack, steering shaft, bump steer kit) 1699.00 We can add shocks
LCA - 183.00
PHB - 128.00
Anti Submarine bar - 30.00
Removable steering wheel kit - 210.00
MS 9" housing - 1010.00
CM 9" housing - 1725.00
Add:
Tie Downs - 47.00
Anti Roll Bar - 379.00
Wheelie Bar Brackets - 140.00
Powdercoat - 100.00
Axles and center - Call
Brakes - call
Billet 17x7 and 17x11 Street lite combe - The 17x7 are 256.50 per wheel and the 17x11 are 323.50 per wheel
Champion Front - 219.95
Champion Rear 15x10 Double Bead Lock - 665.95
Add 20.00 per wheel for 15x12
Billet Specialties rear Double Bead Lock
15x12 - 889.99
15x10 - 879.99
Aerospace Brakes
HVAC - 53.00
LCA - 183.00
PHB - 128.00
Add:
Tie Downs - 47.00
Powdercoat - 100.00
Brakes - call
15x12 - 889.99
15x10 - 879.99
LS1TECH Sponsor
We have not done a bumper support with the prochargers. If you let us know where they mount we can get you set. Does any part of them sit inside the frame rails?
i had to drill 2 holes on the bottom side of what i believe is the factory bumper support. heres a link to a bottom side picture so u can see exactly where they bolt to.
http://exoticperformanceplus.com/per....html?item=539
