Manual Transmission - Best Brand ATF
View Full Version : Best Brand ATF
feelnlo
06-24-2009, 05:40 PM
First, I did search and I've seen all the debates about synthetic vs conventional ATF for the manual transmission.
I'm going to use NON-synthetic Dexron III....
What's the best brand ATF to use for my manual transmission?
I know Castrol ATF is available locally.
Anyone vouch for its quality?
I saw Coastal ATF but it looks cheap and I don't know anything about them.
I'm just very particular. Thanks
crainholio
06-27-2009, 08:51 AM
Any reason you don't want to use synthetic fluid, being "very particular" and all?
Castrol ATF is fine, I ran it in my rebuilt T56 for ~1000 miles and it shifted fine.
I'd really consider spending a few extra bucks and using Mobil-1 ATF.
NVR_SPDS
06-29-2009, 10:03 PM
WIth our stock trans, i ran Mobil 1 with no issues, and with our built T56, i run Royal Purple.
bigsticksupra
06-30-2009, 12:34 AM
I've had really good luck with Mobil 1. My car used to grind going into gears when it was really cold out and just by switching out the dexron III to Mobil 1, it went away and shifted smoother.
MeentSS02
06-30-2009, 08:25 AM
Dexron III is a spec, not a kind - Mobil 1 ATF meets the Dexron III specs.
black01_WS6
07-01-2009, 09:00 AM
Mobil 1 is what I use and a lot of other on here use as well
the Mobil 1 ATF fluid.
